TPS % increases as car warms up? Not anymore!
Old Apr 20, 2011 | 08:15 PM
joefish1298's Avatar
Default TPS % increases as car warms up? Not anymore!
Sorry if this is a n00b EMS question, I googled but couldn't find an answer to my question.
Before starting my car, the throttle (TPS) reads 2% at 0. As the car warms up this climbs until TPS reads 4.5% at 0 when fully warm. Is this normal due to expansion of the throttle body or do I have some kind of other problem, thanks.
J.
Old Apr 22, 2011 | 11:20 PM
H22toF20's Avatar
This is odd. You're TPS should always read 0% unless you're on the throttle.
EDIT Actually, is your car DBW?
Old Apr 23, 2011 | 03:35 PM
No, the car is not DBW, it's a 2001. The TPS will never read 0% with the 30-6052 because when you run the throttle config wizard, it will set min TPS as 2% and max TPS as 98%, but regardless whatever the minimum is configured as this will rise slightly as the car warms up.
Old Apr 24, 2011 | 03:23 PM
H22toF20's Avatar
I'm not familiar with AEM yet. With Hondata S300, I know you can set the min/max %, in case your TPS is off or you ditched the IACV and run with the throttle slightly open for idle. Can you do this with AEM or does it do it by itself?
Old Apr 27, 2011 | 06:47 PM
Originally Posted by Evans Tuning
I have noticed this on quite a few series 2 AEM applications (all honda). I manually scale the min TPS voltage so that when the throttle is closed when warm you see about 0.5%, this keeps the sensor output at idle happy in both cold and warm conditions.
Thanks for the reply. I had thought of this but was worried by setting it that low when warm, that when cold it would go < 0% and throw a TPS error. I will set it up like this anyway and see how I go.
Old Jun 23, 2011 | 10:25 PM
I tried setting the TPS to 0.5% when warm, but did end up with with TPS error on cold start. This meant that the AEM ceased idle feedback and my cold start idle was terrible.
I have reset 0 throttle to 0.5% when cold, which means when the car is fully warm 0 throttle will read between 2.5% to 3%. I set idle feedback to be active at < 4% so it covers all situations with a small buffer and have found this to work well.
Old Oct 12, 2011 | 02:21 PM
Mr Sparkle's Avatar
Hi Guys, a question if I may: -
I just got an OBD2 reader and noticed that when I apply full throttle, the TPS is only reading 89%. How can this be remedied? I assume this means that it is not giving me 100% power when I floor it? A poster above alluded that these values could be adjusted but do I need some software to do this or a trip to Honda? It seems odd that a WOT would give less than 100%(?)
Edit: Could it be that the ECU is seeing 100% but the OBD2 is just being stupid? When warm with the throttle shut it's giving a 4.5% throttle value.
Thanks...
Old Oct 13, 2011 | 07:31 AM
jh4db536's Avatar
Although your tps may not indicate 100% your MAP sensor will show ~0 vacuum when the throttle plate is wide open. The fuel and ignition are based on map load
The tps is used to detect decel fuel cut, fuel surge for acceleration, idle conditions mainly
Sent from my T-Mobile G2 using Tapatalk
Old Oct 13, 2011 | 07:57 AM
Mr Sparkle's Avatar
I see, thanks for the reply
Old Feb 7, 2012 | 04:11 PM
I recently received my EMS back from AEM after repair for a different sensor voltage issue (voltages slowly increasing over a period of months). After return, the behavior described in this thread is no longer present.
I don't know if it's due to the repair, or due to the newest firmware (01v24), but I would suggest anyone who has the 30-6052 with 01v24 and the behavior described in this thread (TPS% increases by a few percent as car warms up) has a problem and should send their unit back to AEM for repair. You will save yourself numerous costs in the long term.
beefystud
Jun 13, 2018 10:29 AM
bruceski
Oct 10, 2014 09:39 AM
OvErMiNd
Jul 25, 2006 08:05 AM
RXDI
Jun 21, 2006 09:48 AM
