System Install
Old Apr 26, 2011 | 11:07 PM
Ragnarok043's Avatar
Default System Install
took me about a year and a half to piece my system together and im finally starting with my install, heres a pic of whats going into the car.
for the headunit ill be using a Pioneer DEX P99RS, speakers Focal KRX3 and McIntosh MCC406M, sub JL 10W6V2 and JL 500/1.
this is the 3" Mid, i made a ring out of 3" ABS tube. it didnt fit perfectly so i spaced it up with white strips of styrene plastic till the speaker fit snug.
so i decided to put the amps in the flat tire well, the McIntosh amp is sitting on top of the board and the JL amp is mounted underneath the board. for the sub ill be fiber glassing a side firing sub, here i got the MDF Ring cut out. for the distribution block, im still deciding but the divot behind the gas tank looks perfect.
here i got the sub area masked off with 3M blue painters tape, after that you can apply a mold release such as PVA. instead i chose to spray a general purpose adhesive onto the masking tape and applied a 0.7mm LDPE(plastic drop cloth) as a barrier. honestly i shouldve used aluminum foil, it wouldve been easier to conform to all the surfaces but i went with LDPE because i could apply in layer with no seams.
after its been masked off you can go ahead and murder somebody hahaha j/k this is the first layer of fiber glass. i added red dye to the resin for better visability to avoid unwanted drips. for the first layer im using woven fiber glass mat, second layer with be baltic mat and third with chopped mat.
for those thinking about fiber glassing your own sub enclosure, this is your best friend especially for the over hang areas.
Old Apr 27, 2011 | 02:26 AM
jonner's Avatar
Keep up the good work...
Old Apr 27, 2011 | 05:39 PM
aphex4000's Avatar
Looks great so far. Can't wait to see more of it!
Old May 15, 2011 | 10:53 PM
mini update, finished layering up the fiberglass shell and trimmed.
here it is with the sub positioned to fire towards the cabin and away from the trunk lid and mounted the mdf ring. next up im gonna apply a stretch to shape the front of the enclosure and a few more layers of fiberglass.
Old May 16, 2011 | 06:06 AM
honda138's Avatar
nice gear
Old May 16, 2011 | 06:47 AM
DangerZone9K's Avatar
I have the same amp and sub. My JL sub is enclosed in the prowedge box... I like the sub but if you turn the bass up then the trunk rattles a lot.
Old May 16, 2011 | 08:24 AM
yeah thats what i figure since the trunk lid is so light. which is why i decided to aim the sub in that direction, to help alleviate some of the rattling but i will be dynamatting the ttunk lid.
Old May 27, 2011 | 01:20 PM
cvjoint's Avatar
McIntosh, classy! I think you'll find if you get rid of the rear tray, spare and paneling that the lid will rattle less. I didn't treat mine and it's fine unless I really push the subs near max capacity. Removing those items will give you usable output too. I can't imagine you hear much of the subsonics this way with the sub virtually separated from the cabin.
Old May 27, 2011 | 11:01 PM
originally i was planning to go with a P800PRS, Focal KRX2 with my Audison VRX4.300 but i stumbled upon a killer deal on the McIntosh and the P99RS just came onto the market. anyways ill probably have make adjustments along the way, worse cast scenario i can get rid of the spare tire and make a new enclosure to channel the sub directly into the cabin similar to yours except itll be sealed.
Old Oct 4, 2012 | 05:02 AM
CDjunkie's Avatar
Very nice!
