MAP Voltage
Old May 28, 2011 | 12:44 AM
Olish's Avatar
Default MAP Voltage
Hello Guys !!!
I need your help please
My friend and I are thinking that I have a problem with my AEM EMS.
Before to send back to AEM for checking and fixing (in case it's corupted)I would like to double check because I'm living in South Pacific
My engine is not starting anymore !!! and this is what we saw quite strange :
With the AEM EMS ecu :
*3bar MAP sensor connected ( http://www.hondata.com/tech3barmap.html )
MAP Computer value : 2.75 volts
Multimeter value : 2.73 volts (using the ground of the battery)
OEM HONDA ecu :
MAP Computer value : I don't know
Multimeter value : 1.66 volts (using the green/yellow wire as the ground)
Multimeter value : 1.67 volts (using the ground of the battery)
So if you could let me know your value, that will really help me to solve my problem even only on the computer...(AEM program)
Thank you in advance for your help
Old May 28, 2011 | 04:47 AM
wadzii's Avatar
Banned
First off, throw that map sensor away and get a good one.. those GM sensors are JUNK. They are slow, they do not have a linear response, and they are JUNK, there is a reason they are $20
Old May 28, 2011 | 08:37 AM
Olish's Avatar
Thanks for the advice !!!
Old May 29, 2011 | 08:37 AM
wadzii's Avatar
Banned
have you tested the aem with the stock map sensor?
Old May 29, 2011 | 10:27 AM
Olish's Avatar
Yes I also tested with the stock MAP sensor only :
*OEM MAP sensor only connected
MAP Computer value : 3.24 volts (using the green/yellow wire as the ground)
Multimeter value : 2.35 volts (using the green/yellow wire as the ground)
MAP Computer value : 3.24 volts (using the ground of the battery)
Multimeter value : 3.21 volts (using the ground of the battery)
OEM HONDA ecu :
Multimeter value : 2.96 volts (using the green/yellow wire as the ground)
Multimeter value : 2.97 volts (using the ground of the battery)
Old Jun 12, 2011 | 10:41 AM
Olish's Avatar
Update :
I received my new AEM EMS and the voltage is ~1,61....1,62 volts
And my car is starting now.
chtmatthew
Feb 13, 2019 05:58 AM
jco2301
Sep 4, 2018 04:03 PM
blink962
Oct 10, 2016 08:04 AM
SpaS2K2005
Mar 11, 2010 12:50 PM
GDM S2K
Jun 21, 2006 04:34 AM
