Hugely annoying rattle fixed
Old Sep 5, 2011 | 07:16 AM
Azbola's Avatar
Default Hugely annoying rattle fixed
So I just thought I'd tell anyone that's interested, I have had a utterly annoying rattle for some time that was getting worse and I managed to track it down by parking the car and letting the clutch up with the brake on. This lagged the engine and made the vibration start. Then poked around a bit (with a golf club... maybe not a great tool) and found it was the exhaust pipe.
Being lazy I took it to the Honda garage and it was apparently 4 bolts missing from the heat shield and hey presto it is now all better. Hooray!
Actually, not a very interesting story now I come to re-read it....
Old Sep 5, 2011 | 08:48 AM
Squeak's Avatar
Nice to know it is an easy fix, I think mine is rattling
Old Sep 5, 2011 | 09:25 AM
POG's Avatar
POG
Where did you hear the rattle from? I have a metallic/glass rattle from behind the driver's seat. I say glass because it reminds me of the sound of glass valves in a guitar amp. Is that similar to what you were hearing?
Old Sep 5, 2011 | 09:27 AM
WinFreak's Avatar
Have you checked the spare wheel fixing bolt?
Old Sep 5, 2011 | 09:28 AM
lovegroova's Avatar
That's likely to be the spare wheel (if it's there). Tighten the bolt.
Old Sep 5, 2011 | 09:43 AM
Squeak's Avatar
I will check the spare wheel but yes it is that glass type sound as described
Old Sep 5, 2011 | 09:54 AM
jimmyb1978's Avatar
my cat heat shield is loose and its a job I keep meaning to do.
Old Sep 5, 2011 | 10:17 AM
POG's Avatar
POG
Yea I did check the spare wheel some time ago. Thanks for the suggestion though. I will take more time to check the car all over.
Old Sep 5, 2011 | 09:47 PM
veehexx's Avatar
my rear tray is annoying me...sooo tempted to pulll it out! rattly pos.
Old Sep 6, 2011 | 04:09 AM
Azbola's Avatar
To those asking what this sounds like, it sounds just like two bits of metal knocking together
Probably about 5 knocks per second.
Mine was happening when pulling away from standstill, and then again at about 4K revs.
Ks320
Jun 29, 2009 03:21 PM
porschedave
May 10, 2008 01:48 PM
redlineracing
Nov 8, 2004 12:39 PM
KMCC
Aug 10, 2002 11:53 AM
RxS2K
Dec 18, 2000 07:30 AM
