Rattle
Old Apr 27, 2008 | 04:49 PM
porschedave's Avatar
Default Rattle
I have noticed that there is a "clicking" rattle sound when the passenger window is fully wound up to the stop position. This occurs whether the top is up or down, when a passenger is sitting or not and when the seat belt is properly engaged. The noise stops when I slightly lower the window by a 1/2 " . Appreciate any ideas, suggestions or whether others have experienced a similiar issue. Thanks!
Old Apr 27, 2008 | 06:06 PM
duanet85's Avatar
i got a rattle on the passenger door, but i'm pretty sure mine is the speaker
Old Apr 27, 2008 | 06:14 PM
SIIK2NR's Avatar
^^ Is there an echo in here?
Most likely if it's not the seat belt is the soft top bracket. Do a search for rattles and you will find a thread on how to eleviate the rattles from the hinges and soft top.
Old Apr 27, 2008 | 06:22 PM
Thanks for the suggestions. I did search for the soft top hinges. However, the sound is heard with the topdown from the window. Apparently, it is not the speakers. I have isolated to the window itself. The concern I have is needing to undo the door panel to investigate the window mechanism
Old May 10, 2008 | 01:48 PM
Found the culprit. The Honda dealer and I realized that the clicking noise emanates from where the plastic interior door frame meets metal. Foam tape solves the problem!
hondahead211
Sep 14, 2022 02:38 PM
MikeyCB
May 6, 2014 09:20 AM
kingpin78
Apr 30, 2013 03:36 PM
volkdc2
Feb 14, 2012 10:50 PM
dsthez
Aug 26, 2009 08:24 AM
