Replacing license plate light?
Old Sep 25, 2011 | 11:01 AM
liquid_helix136's Avatar
Default Replacing license plate light?
Hey guys,
So I got pulled over for the 2nd time in about a month for my license plate light burning out. You forget you even have one until you get pulled over once it burns out
Anyways, after the first warning I decided to see if it happens again, as I dont REALLY care if my license plate light works or not. But it happened again about a month after the first occurrence and so now Ive decided to fix it up.
After giving it a good look, It seems like its gonna be a bit more of a hassle to replace than I originally thought. Anyone have a DIY on how to do this? I dont think this site has one yet, and heres to hoping that the reason behind that is because its so easy to do
Old Sep 25, 2011 | 11:10 AM
s2000maniac's Avatar
com on dude, really?
it's in your owner's manual.
Old Sep 25, 2011 | 04:58 PM
skkppy's Avatar
1. firmly squeeze on the clear plastic lens above the license plate and pull towards the ground
2. pull old bulb out
3. push new bulb in
4. replace clear plastic lens
finished
Old Sep 25, 2011 | 08:22 PM
redlining's Avatar
When did they start putting license plates under the hood? Kinda seems like a weird place to put it haha
Old Sep 25, 2011 | 08:28 PM
iVTECallday's Avatar
DIY for blinker fluid and muffler bearing replacement???
Old Sep 26, 2011 | 03:16 PM
lol
Thanks, guess I should have given it a bit more than a look, a wiggle, then said f@#k it ill check s2ki
Old Sep 27, 2011 | 04:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The clear lesse easily prys out with a dime or penny.
Old Sep 27, 2011 | 05:02 AM
dcmonkey's Avatar
or car keys and house keys work great too!
Old Sep 26, 2015 | 06:45 AM
Chuck S's Avatar
Reviving this 'cuz I just had to do it.
On my '06 AP2 all I did was stick a screw driver between the side of the cover and base and and gently pry one of the side edges away and the cover fell off. Squeezing probably works too.
Old bulb pulls straight one, new bulb presses in.
I washed the clear cover and snapped it back on.
Other than the washing part it took less time than typing this.
-- Chuck
Old Sep 26, 2015 | 01:46 PM
Slowcrash_101's Avatar
You should invest in LED's they'll never burn out...pretty much. My interior lights, my tag lights, and side turn lights are all LED, and I can rest easy knowing I probably won't need to replace them....ever. The wiring on the other hand....
