Project 1050
#101
What MB is saying would make a lot of sense. Also id consider a roof vent for your hardtop when the vents go. It gets pretty hot in there over summer time, especially the left leg.
#102
Originally Posted by dave.irl' timestamp='1377608900' post='22746997
Have you driven the car in the rain for extended periods with out the heaterbox. Thats my big worry that I cannot demist them
#103
#104
So yesterday I pulled the dash and the HVAC system as earlier suggested. Here is what all the parts are like out of the car
and the empty dash
I weighed the parts. If anyone is interested
Blower fan = 1.16 kg
Heater core = 3.55
Evaporator core = 4.04 of which the rad is ~ 2kgs
Assorted piping and foam that came out was 1.59kgs
So about 10.5 kgs + the weight of the coolant.
Since I want to retain airflow to the windows, what I am going to do is to keep the blower and the unit its attached too (without the aircon evaporator rad), remove the heater core completely and the vents under that dash, and using some flexable ducting, run a duct from the blower to the intake of the vent that blows air over the windscreen.
This is about 3.5kg, so still a reasonable weight loss ( ~8 ). And I retain stock fan controls and recirculation controls too
Also if anyone is thinking of doing this, the ECU needs to be unbolted and it uses 3 triangular lobed bolts for which I don't have a tool to remove. So I cut the lower two off with a die grinder. There is plenty of room to do this. You cannot get the the upper bolt, so the simple solution is to look for 2 10mm bolts which hold the bracket at the top of ecu to the chassis. These can be easily got at with a universal joint, and will be release the ecu. Replace the bolts with standard hex bots and your done. 15 minutes or so it took me
Also since I took them off, here are the weights of other components
Passenger airbag 2.95kgs + support bracket (0.6kgs)
Driver airbag 1.13
Guage cluster 0.82kgs
CLuster surround 1.05
Dashboard ~5.5-6kgs, My scales only go to 5kgs and this went over, by feel compared to heater, this would be my guess
and the empty dash
Heater core = 3.55
Driver airbag 1.13
#108
#110
