View Poll Results: What tires (primary) do you use?
Hankook R-S3 255
45.13%
Hankook R-S3 245
3.98%
Dunlop Star Spec 255
21.24%
Dunlop Star Spec 245
5.31%
Toyo R1R 245
0%
Toyo R1R 255
0%
Other
20.80%
BFG Rival 255
3.10%
BFG Rival 245
0.44%
Voters: 226. You may not vote on this poll
STR Prep - Wheels and Tires
Old Oct 19, 2011 | 11:37 AM
Random1's Avatar
Default STR Prep - Wheels and Tires
=============== STR Threads ===============
STR Prep - Suspension and Alignment
STR Prep - Shock / Damper and Springs Discussion
STR Prep - Differential Discussion
STR Prep - ECU and Tuning Discusson
STR Prep - Exhuast (tip to tail)
STR Prep - Weight Reduction
STR Prep - Sway Bars
SCCA Solo - STR Rules Discussion ---> (Debate rules and proposals here...)
STR Prep - AP1 vs AP2v1 vs AP2v2 vs CR
STR Prep - Intake • from DIY to Mugen
STR Engine Mounts
What wheels and tires do you use?
Tires
Hankook R-S3 ----------------------------------- Dunlop Direzza Sport Z1 (Star Spec)
Wheels
949 Racing 6ULR (17x9 +63) 17 lbs
TR (Tire Rack) Motorsports C3 (17x9 +62) 18.8 lbs
TSW Nurburgring (17x9 +63) 19.2 lbs
Enkei Racing PF01 (17x9 +60) 17.2 lbs
Volk Racing CE28n (17x9 +63) 14.8 lbs (est)
UPDATED 9/17/13
Car: 2003 S2000 AP1
Weight: 2650 lbs with 1/2 tank
Shocks: Penske 8300
Shock Body Length (lower bolt center to top of body/shaft bearing): Front = stock " --- Rear = 10.5"
Valving: Custom
Pistons: Compression - digressive --- Rebound - Linear
Springs: Hyperco 7" 950f/ 8" 750r
Front Sway Bar: Comptech Adjustable on full stiff (~900 lb/in)
Rear Sway Bar: 2006 MX-5 Front Bar with stock MX-5 bushings
Ride height: 12.25"f/12.5"r hub center to metal fender edge
Tires: 255 square Hankook RS3
Wheels: 949 Racing 6ULR 17x9
Alignment
Front Toe: 0.0 in
Front Camber: -3.0 deg
Caster: 5 deg
Rear Toe: -5/16"
Rear Camber: -2.6 deg
My wheel and tire page
Old Oct 19, 2011 | 11:42 AM
daverx7's Avatar
Due to the cost (great bang for the buck), I am going to be with the norm here:
Wheels: 949 Racing 6ULR 17x9 +63
I've tried the RE11's and the R1R's, and we just like the R-S3's better. But, I must admit that the longitudinal grip on the R-S3's doesn't seem to be as good as the R1R's.
-Dave
Old Oct 19, 2011 | 11:48 AM
whitt1's Avatar
Tires are Hankook 255/40-17
wheels TR3 17"X9" +63
I'm seriously considering trying TR3 17"X9" +48 on the rear to gain extra rear grip by widening the rear track.
Old Oct 19, 2011 | 07:21 PM
josh7owens's Avatar
Car: 2000 S2000 AP1
Weight: 2600 lbs
Alignment: -2.9f, -2.5r camber, 0" toe front, 1/4" rear toe (2012 set-up)
Old Oct 20, 2011 | 07:11 AM
imstimpy's Avatar
I prefer the feel of the Dunlops every time. My driving style is very precise and I just don't like sliding around. They wear more evenly than the Hankooks and handle water better, but are not as forgiving with slip angles or temperatures.
With that said, I run two setups:
Temperatures below 80*F
Tires: 255 Dunlop Z1* @35psi
Temperatures above 80*F
Tires: 255 Hankook RS3 @35psi
Old Oct 20, 2011 | 11:13 AM
zo7vette's Avatar
I thought I would add these to the list of great looking, decent weight 18.4lbs, and great value.
http://tsw.com/alloy_wheels_nurburgring.php
17x9" TSW Nurburgring 63mm
I have a set of the Gunmetal.
My first set of tires are 255/40/17 Dunlop Star Specs.
Old Oct 21, 2011 | 08:13 AM
IntegraR0064's Avatar
Where'd you get 18.4 lbs? I was under the impression that they were in the 17.x range, similar to the 6ULRs?
To answer the original post, next year I'm going to be joining the camp of:
Local Events (all) and National Events (sunny and warm or cloudy and hot): 255 Hankooks
National Events, rainy or cold and cloudy: 245 or 255 dunlops, haven't decided yet, leaning towards 245
Rallycross: Hoosier A6 (....ok maybe not)
Old Oct 21, 2011 | 09:13 AM
zo7vette's Avatar
I weighed them on my digital shipping scale, they are 18.4 lbs.
Old Oct 21, 2011 | 09:16 AM
OK that makes sense, I think the high 17 weight I saw was on a bathroom scale or something.
Old Oct 21, 2011 | 12:50 PM
TTMartin's Avatar
19.2 lbs for the 17X9 according to the link you provided.
