Angled oil filter adapter, need some help.
Old Dec 28, 2011 | 10:08 AM
B5254T4's Avatar
Default Angled oil filter adapter, need some help.
I´m looking for a 45 or 90 degr adapter, anyone using this? Would be a perfect way to clean up the engine bay and get rid of the oil lines, would clear the manifold without a problem.
Here´s a pic to explain:
Sorry for all the questions but have a feeling that it might help other members as well.
Old Dec 28, 2011 | 02:54 PM
Deception's Avatar
Nice find. I would have used that if I knew about it.. normal oil filter relocation kits suck. Do they make it in Honda/metric sizing?
Old Dec 28, 2011 | 08:35 PM
B5254T4's Avatar
That´s why I need you guys, JEGS and Summit should have some but my English suck. Sometimes the adapter itself work if you modify/change the thread size.
Not 100% here but I think we have M20x1.5, found a nice one yesterday using 3/4", will buy that one (used for 20 bucks) and see if I can make it work.
Like the middle or last one.
Maybe FBM can machine a bunch?
Old Dec 29, 2011 | 02:23 AM
Phill24's Avatar
this is a very good idea save u the hassle of getting oil lines made or worrying about oil pressure
Old Dec 29, 2011 | 12:59 PM
Deception's Avatar
yeah you only need to make it work on the motor side, just use whatever filters fit on the other side, doesn't have to be a honda filter. I ran filters for a Ford V6 on my kit.
Old Dec 30, 2011 | 01:55 PM
rrounds's Avatar
I would buy one with a smaller thread(to the block) so you can drill it out and tap it to the Honda's M20 X 1.5 thread.
Go do it and get back to us. Very nice find.
ROD
Old Dec 30, 2011 | 02:16 PM
B5254T4's Avatar
Bought one today, will start working monday, will keep you updated. Will go Honda threads since I want to keep it simple and according to many the S2K filter´s the only good option.
Thanks guys and Happy New Year! (Go Cerrone and Alex)
rrounds's Avatar
If I did this right you should be able to tap out the bolt that holds the oil filter adapter to the block from 3/4" thread to M20 X 1.5 thread.
0.75 inch = 19.05 millimeter
And then you could run a big filter like this
http://www.wixfilters.com/filterlook...asp?Part=51515
and if that filter isn't big enough they make a 2 Qt. filter for 3/4 X 16 thread.
I run a very large filter(over twice as big as the stock S2000 filter) on my "S" and this would work real good on my car.
Thank's for finding that adapter,
ROD
Old Dec 31, 2011 | 11:52 AM
Ilike2DRIFT's Avatar
Great find! If this works i am def considering getting this over my greddy/canton relocation.
What manifold you running B5254T4?
Old Dec 31, 2011 | 01:34 PM
passmans2kny's Avatar
good info, i may do this if u guys find a model that works
