Front grill
Old May 29, 2012 | 06:50 PM
bkowa092's Avatar
Default Front grill
I remember reading a thread on here a few months back about the front plastic grill falling out/coming loose on a lot of s2000's. Just wondering what everyone did to assure it stays in place? I was thinking double-sided tape around the sides, but I'm open to all suggestions.
Old May 29, 2012 | 07:28 PM
AP1Theory's Avatar
Grill coming loose? On the front bumper?
Old May 29, 2012 | 07:42 PM
bkowa092's Avatar
Yeah, the black piece in the front bumper. It's only held on by a few "tabs" that can eventually snap off. I remember reading about other people having this issue, but at that time I was not having the issue.
Old May 29, 2012 | 08:10 PM
chubbychu's Avatar
Speed nuts and flush/washer screws! Do it! it won't go ANYWHERE.
Old May 29, 2012 | 11:31 PM
AP1Theory's Avatar
I am confused and I might sound stupid, but MY03 has a solid piece of plastic as a front bumper with nothing held on besides the license plate and misc metal pieces to bolt on the mud guards and the bumper itself. The Grill is part of the bumper.
Old May 30, 2012 | 04:43 AM
SkateForGirl's Avatar
http://www.hondaautomotiveparts.com/...tcgry5=BUMPERS
Go to number 33 on here. It's a bunch of 3.5 mm speed nuts. Hope this helps.
Old May 30, 2012 | 05:09 PM
bkowa092's Avatar
Thanks for the replies everyone!
The speed nuts (#33 in diagram) aren't supposed to be there from the factory, are they? My front bumper is oem, and it does not have any speed nuts. Just a series of prongs that go inside of holes on the bumper itself. By the way, this is a 2006 s2000 that I am talking about. I am not sure if the ap1 grille mounts the same way.
Old May 30, 2012 | 06:21 PM
Yes they are supposed to be their from the factory. People sometimes pull the grills out and don't relize those hold the grill in so maybe that's what happened if you are a second owner.
Old May 30, 2012 | 06:22 PM
chubbychu's Avatar
#33 IS there from the factory.I have an ap2. Your plastic prongs should have metal type clamps, crimped onto the back of them. If your grill is falling out it's either because a few of those those prongs have broken off, or...you lost your clamps somewhere.
I assume you can see the slots where it lines up with the bumper. If you don't mind drilling 2 holes through the grill, just line it in, then put the "u" type speed nuts onto the existing bumper slots, then screw through the plastic grill piece into the "U" type speed nut.
Good luck!
Old May 31, 2012 | 07:19 PM
JDMricist's Avatar
Mine keeps falling out too.. I tried some Quickplastic and it held for awhile till I tapped a parking block.. Would gorrila glue help?
