rear speaker wiring
rear speaker wiring
Ok, I'm new to the S2K1 forum. I'm trying to install rear speakers in my 2003 S2000. Lots of posts that say how easy it is, but NO instructions on connecting 4 rear speaker wires to the radio harness!!!!!! Anybody have a list of instructions?
Unless you just hack into the wiring for the front speakers... Effectively giving you 2 Front Right and 2 Front Lefts...
However, this would work until you get an aftermarket head unit that supports rear speakers. Then you just run the speakers directly to the rear speaker wiring on the after market deck.
... then there is a Line Out Converter option... but that isn't the best option for what you're trying to do.
I thought the stock headunits did have rear speaker output... from what I remember, the oem harness just doesn't have the connections for it or something along the lines of that. In the first couple years of the S2000, Lucid sold a harness that let you easily connect rear speakers.
I believe it was..
LR + Blue/Yellow
LR - Gray/Red
RR + Red/Yellow
RR + Brown/White
or I'm just losing my mind...
But anyways, I wouldn't recommend using the stock headunit anyways. A cheap $100 headunit will sound 500x better and be easier to set up with rear speakers.
I believe it was..
LR + Blue/Yellow
LR - Gray/Red
RR + Red/Yellow
RR + Brown/White
I believe it was..
LR + Blue/Yellow
LR - Gray/Red
RR + Red/Yellow
RR + Brown/White
I believe it was..
LR + Blue/Yellow
LR - Gray/Red
RR + Red/Yellow
RR + Brown/White
trust me...im an old head that doesnt "bump" his music and the stock headunit does not sound good...night and day difference...you dont need to have a lot of power and big speakers to make your music sound better...youre going to be missing out on a lot of sound quality keeping the stock headunit
Originally Posted by franky' timestamp='1338828206' post='21752644
of course it's easy. Piece of cake. but first, do you have aftermarket stereo or stock?
Left Front Speaker Wire (+): Green/Yellow
Left Front Speaker Wire (-): Gray/Red
Right Front Speaker Wire (+): Green/Black
Right Front Speaker Wire (-): Light Green
All you have to do is run some speaker wires along the center console or under the carpet to the back and hook up the wires. T tap the wires to the stock stereo wires and there you have it, rear speakers except it will be two left front speakers and two right front speakers. So when you upgrade your stereo, you can just wire up the rear speaker wires on the aftermarket stereo to your rear speakers.
