My top won't stop ripping
So my stop keeps ripping in the usual spot on the passenger side. I bought modifry straps, patched it with marine vinyl and glued it with Goop and it keeps happening over and over. My only other thought is that the bar that rubs on it is still sharp. Problem is, every time is described or mentioned in a thread, there never seems to be a pic posted of it and someone refers to some thread it's in that I can never seem to find.
Can someone please post a pic of the spot on the bar that needs to be filed down, so I can hopefully be done with this problem? Thank you!
i just copied this from another thread. put some lizard skins around the arms.
if you dont know what lizard skins are:
https://www.s2ki.com/s2000/topic/730...#entry17115581
i did this to my 03 and the top is flawless.
file or tape up that sharp edge
Also, i assist my top going up or down whenever I can by helping the most forward and rear bars
yes, that's what a lizard skin does but many cyclist including myself just wrap electrical tape or wrap an old inner tube around the frame parts and secure the ends with electrical tape lizard skins aren't cheap and shift time to time
No one has a pic of the exact point that causes the hole?
SEE THE ARROW IN POST 15 from the link right here ^
Also, the picture shared in your thread with the black line is from an ap1 frame. ap1 frames are slightly different and don't have that ap2 sharp edge
Depends on the specific soft top frame. Mine wasn't cutting at the point indicated by the arrow in the photo in the post you're referring to. As other posts state, deburr any sharp points on the frame and coat. If you slowly lower and raise the top you'll see where rubbing takes place against wherever you're developing a tear.
