Asia S2000 Owners English speaking owners from Asia. Including Hong Kong, China, Japan, Singapore, Malaysia, Taiwan.
Help translating instructions please!
Old 05-20-2011, 09:55 PM
Boofster's Avatar
Default Help translating instructions please!
Can someone please translate these?
Usually they are self-explanatory but I really have no idea what's going on in the last two images.
Would be nice to know all the notes about this to do it correctly.
Thank you!
Old 05-24-2011, 05:26 PM
Mr2000's Avatar
Now maybe I'm wrong...
From left to right top to bottom:
If you adjust this doohickey just right, your car will float
Now because wheels aren't very efficient at flight you simply remove the wheels, and this bolt, then replace with a flux capacitor, and replace the bolt
The end results being the black part of the bar graph at the bottom
Yay!
Good luck with the translation my friend
Old 05-31-2012, 04:35 PM
Berlina.07.AP2's Avatar
Rough translation...
5) If the collar is too-large and doesn't fit then the outside of the collar needs to be ground-down with a 'belt-sander'.
6) If the hole in the upper sub-frame appears too narrow, ensure the position of the collar is correct and ensure there is no weld-splatter interfering with the fit. If weld splatter is present, grind down with hand grinding tool(e.g. Leutor) as shown.
Does that make sense?
vtecmonster
05-08-2020 07:45 AM
ceejs2k
01-05-2018 08:01 AM
Dembo
Car Talk - Non S2000
08-01-2015 11:53 AM
s2000Junky
01-31-2013 12:17 PM
AustinS2k2003
10-19-2004 03:51 AM
Quick Reply: Help translating instructions please!
