Automotive builds Got an automotive build you want to want to document? Post it here!
o_O S2000 | Mk I — Stage II
Old 09-16-2016, 01:39 PM
  #2861
andrewhake's Avatar
Originally Posted by RussianHammer
I seen the air ram they made for their customer on the blog before. It looks like a one off piece made from aluminum. It looks like something you can make yourself as well, and i seen a few people have similar designs to use with the V2 mugen. i wanted to make one for my intake as well.
The valves are essentially like blow off valves, but with a steep price.
http://japan.webike.net/products/21955052.html
Yeah the price on those valves is a bit silly.
Old 09-18-2016, 11:53 AM
  #2862
andrewhake's Avatar
This updated tune is bananas. It really is just VTEC on demand basically. Having access to it at 4000 is amazing. When I am in the changeover window the transition is nice and smooth too.
Old 09-18-2016, 12:41 PM
  #2863
iLuveketchup's Avatar
Maaan.... this car is awesome!!
Old 09-19-2016, 01:24 PM
  #2864
RussianHammer's Avatar
This is one of the reasons why I have been considering the Apexi Neo. To be able to drop the Vtec up and down whenever you need it.
Old 09-19-2016, 01:27 PM
  #2865
Ricky_Flowers_'s Avatar
Why not go with a full standalone? The difference Andrew is feeling is not purely due to his VTEC threshold being lower, but his tune is optimized for his bolt-ons. Unless you're in a points-based class like NASA TT or whatever, or you're autocrossing, there's no reason why you shouldn't get an aftermarket ECU.
Old 09-19-2016, 01:29 PM
  #2866
andrewhake's Avatar
I think the SOS AEM infinity setup looks to be the best option now for pre-06 models. https://www.scienceofspeed.com/index...0-2000-05.html
Old 09-19-2016, 01:31 PM
  #2867
andrewhake's Avatar
Originally Posted by Ricky_Flowers_
Originally Posted by RussianHammer' timestamp='1474320272' post='24065262
[quote name='andrewhake' timestamp='1474228389' post='24064502']
[/quote]
Yeah agreed. The extra money spent on a full standalone is well worth the cost for all the optimization and much simpler ease of use and tuning. Being able to optimize for the current parts is the real advantage, keeping everything within a safe limit and get large midrange increases at the same time. Just changing the VTEC changeover window won't get you that.
Old 09-19-2016, 01:48 PM
  #2868
I was referring to just the vtec. I don't need a full standalone, and probably never will unless i continue to get bolt ons. This is not the case right now.
Old 09-19-2016, 06:22 PM
  #2869
andrewhake's Avatar
If you have an intake or an exhaust and test pipe, or even just a test pipe then there are significant tuning advantages in full stand-alone or FlashPro when that is an option. Just changing the VTEC change over will cause other small issues making things slightly less reliable over the long run. Not to mention any good stand-alone also able to data log to keep tabs on the engine if it sees mostly track time.
Old 09-25-2016, 07:46 PM
  #2870
andrewhake's Avatar
ASM front lower + rear lower brace
Picked up these used and now discontinued ASM subframe braces from GoTuning. My rear lower subframe brace has been in need of replacement for awhile since it is a bit scraped up. I like these ones since they look like they could be on the car from the factory.
Quick Reply: o_O S2000 | Mk I — Stage II
