Clutch Slave and Clutch Master cylinder
can someone tell me if the
-Clutch Slave Cylinder and the Clutch Master cylinder (for MY2001)
will fit Australia (RHD) model if they are purchase from US (LHD)..
Thanks in advance...am thinking of getting them from Hardtopguy..
Tom
Tom
Thanks Aus.
UK have the same Right Hand Drive as Australia. Some Pommy had ordered from HardTopGuy previously (slave and master) and had no problems with them.
Anyway, recently realized that fluid level in the master is coming down slowly (mysteriously disappearing very slowly). Upon checking the slave...it is where the fluid went missing. So I've ordered the slave from HTG....and might as well do the master too. They are cheaper (plus freight) from overseas, thus the reason for not getting them here in OZ....I had a few maintenance items added with the order too.
Thanks again.
Tom
Thanks again.
Tom
The slave and master from hardtopguy (US) fitted perfectly (on the AUS version).
While at it, replaced the pollen filter, air filter, engine oil (castrol edge 5w-30), oil filter(HAMP), diff oil(Honda Hypoid Gear Oil SAE 75W90 GL-5), gearbox oil (Honda OEM MTF) and spark plugs (NGK platinum oem spec). It was a little tricky re-filling the diff and gearbox oil.
Cheers
Cheers
