Offical Front Sway Bar Thread
#161
i currently have standard my05 front and rear sway bars. i want the most solid sway bars i can find. whats the best way to go for the money? everyone keeps telling me to go for the my99 sway bar as its the thickest oem spec. i also have a front whitline cross member installed.
#162
Originally Posted by LOWPROaero' timestamp='1397450031' post='23110925
[quote name='djeddiebear' timestamp='1380068974' post='22794934']
Oh anyone try out the Godspeed bar? 30.29mm and supposedly solid. Plus it's pretty reasonable at $120. I just can't get myself to purchase the Gendron.
http://www.godspeedproject.com/honda...tag=Sway%20Bar
http://www.amazon.com/gp/offer-listi...&condition=new
They are saying 40% stiffer than stock. But are they comparing it to the MY00 bar which is the stiffest at 393 lb/in? If so, this thing ought to be 550 lb/in. My math which compared two identical bars at 28.5mm and 30.5mm though only resulted in about 520 lb/in. Don't know about material differences etc.
EDIT - I installed this last night. Fit perfectly. Used stock endlinks and it all lined up including bushings etc. Roll stiffness feels significantly stronger. For $80 compared to $350+ elsewhere, lol.
It measured 1.21" OD while the one I removed (stock?) measured 1.06".
[/quote]
slight difference in price!!!! WTF!
http://www.amazon.co.uk/Godspeed-Hon...s2000+sway+bar
#163
Go for the my99 sway bar for £40 & paint it Red that should stiffen things
>93 lb extra.
if you want £500-£700 quality go with ones with bearings
A good read here >
https://www.s2ki.com/s2000/topic/904...rep-sway-bars/
>93 lb extra.
A good read here >
#164
It's for $80 shipped on Amazon now.
#165
Last night I managed to get a MY1999 front ARB which is 28.2mm diamter / 393 lbs, (for £50 delivered from ebay!) this is almost exactly the same stiffness as the MY 08/09 Club Racer front ARB. (Currently my 2002 front ARB at 300 lbs). Now hopefully this front 393 lbs ARB coupled with the std MY02 rear 396 lbs ARB will be a much better setup on my MY02 car & might just be the sweet spot when combined with Coilovers.
#166
^^ was thinking of buying that too,you beat me too it this morning !!
A good combo on coilovers
#167
Also got a MY06 RSB locally for $30 or so.
They both went on my MY03 (similar specs to your MY02). Feels so much better, balanced, predictable and easily controllable. Much more rear grip and traction. A lot less twitchy and floaty feeling during turns.
#169
I got my MY00-01 FSB on eBay too ...it was like $40 shipped lol
#170
