SBG Lower Cup Review
Hi all,
Just wanted to post a quick review on the install of the new SBG Ohlins DFV Extended Lower Cups that have generated a lot of interest on this sub.
Sakebomb Ohlins - Album on Imgur
I've been running autocross on my DFV's for about a year now and as I've learned more about car setup I came to realize that the biggest limiting factor with these coilovers is the rear shock travel and adjustment. In order to get the travel optimized you need preload, but with that preload comes a limitation on ride height. I had begun to investigate a variety of potential solutions that could allow me to add this necessary preload without compromising ride height. I considered installing rear roll center adjusters as well as looking into fitting custom extended top hats to these coilovers. Fortunately for me, SBG reached out to me with specs on their solution, a reworked lower shock mount, and I was sold. I put down a pre-order for the first production run and I couldn't be happier with the solution at such a great price point.
These cups do exactly what is needed with little hassle and I'm hoping that this extra adjustment will help me continue to fine tune my car's handling and performance.
Big shout out to SBG for continuing to provide the S2k community with new and innovative products!
Is it as simple as spin the Ohlins lower off and thread the SBG lower onto the damper? I've been really interested in these since I learned about them two days ago.
Hi all,
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Yup! The mounts are a direct replacement for the standard lower mounts. Simply remove the standard mount and ours threads on in it's place. Our mount will allow a higher than stock ride height all the way down to 2" lower than the standard DFV lower mount.
__________________
Right back at ya! Thanks for the interest
__________________
jst2878
07-01-2014 01:27 AM
needans2k2
06-21-2011 10:19 PM
