Can't find A30 pin for Kpro
Old 12-04-2016, 05:55 PM
  #21
RAIN H8R's Avatar
Originally Posted by flanders
I had a look now and I agree it seems the tuner didn't really know what he was doing, or maybe didn't care.
First of all, you are using a PRB type calibration. I'm not sure what cal was used to start off with but it's not a S2000 so many settings are wrong.
AC clutch switch like you said, lots of fuel compensation settings, ELD sensor and all O2 sensors disabled making it run in open loop all the time.
I suggest you start over with the included S2000 ap1 calibration and change whatever needs to be done like injector settings etc.
Fuel and ignition tables you can copy and paste the whole table, you can run two instances of kmanager which makes it pretty easy.
You will want to run a PRA Cal as you mentioned. Otherwise evap, and other key items will not function properly.
Old 12-05-2016, 07:48 AM
  #22
FinestS2k's Avatar
so I wrote a new PRA cal and I get check engine light p0443 Evap emission control
Old 12-08-2016, 06:57 AM
  #23
RAIN H8R's Avatar
Now that you are running the right calibration, look into why the CEL is happening.
Old 12-08-2016, 07:41 AM
  #24
flanders's Avatar
Since your running a turbo it seems likely that you have parts of the evap system removed or altered.
Old 12-10-2016, 10:02 AM
  #25
FinestS2k's Avatar
stupid me, the boost controller replaces the Evap purge valve wiring so I just have to disable it nbd. Honestly at this point it just got really cold out so the car is in the garage for the winter to be disassembled and cleaned up. Gonna make a new thread that I hope both of you will chime in on.
Old 12-10-2016, 10:24 AM
  #26
RAIN H8R's Avatar
Yup, that is how it is wired.
if I do not reply and you want input, just send me a PM with the link.
solos2k
10-13-2016 06:59 PM
jsenclosure
10-11-2014 07:57 PM
Trunkz
07-31-2014 12:10 AM
s2kseven
11-07-2012 06:11 AM
Blucky87
07-18-2011 12:20 PM
Quick Reply: Can't find A30 pin for Kpro
