vented valve cover bungs
#53
You might need one. I had put a 1" tube on the driver side front of the cover. If I remember correctly, there was not a lot of space between the valve cover and the cam gear. At least not enough for me to build a baffle.
It took less than 100 street tuning miles to fill up a catch can that holds over 32 ounces.
I have the same 1" tube welded on the oem vent. There is oil residue on the can from time to time, but it has never accumulated enough oil to slosh around. I usually check/clean it twice a year and can still see the bottom of the can.
#55
I made two bungs on the front side of the valve cover, but the lines that go to the catchcan, go up first before they go down.
This way there won't be so much oil coming through. After 100miles, still no oil in my can.
#56
im afraid of doing them in the front and filling catch can every month :/
jyeung528
07-20-2010 09:28 PM
