Fuel injector sizing help #2
Ok so I have MY04 AP2 and in getting ready to install:
Haltech Pro Plug In ECU
AEM V2 CAI
Toda Spec C Cams
Toda Valve Springs
Toda Cam Gears
Toda Torquie-Kun Header (60mm collector)
60mm TP
60mm Catback
Is it likely that injector duty cycle will be too high? Will I need new injectors? If so, what size?
AEM V2 CAI
Toda Spec C Cams
Toda Valve Springs
Toda Cam Gears
60mm TP
60mm Catback
Some people would rather test the oem equipment out first to see if there "enough" because they operate in the car so well. Not sure of your year but u might be able to keep oem inj. And just bump fuel pressure by 2-4psi.
