Mugen Header
#21
Research. Then when you think you're found the right part, research some more.
#22
The Mugen header is a well made piece of material. It will provide gains almost through out the entire rpm range, but really needs a tune to show results. I've got the Rick's (Mugen copy) and like it. If I had to do it over though, I'd look to find a used J's which yields slightly better high end hp.
#23
I really haven't saw any thorough testing of any header, so who really knows? A real test would be fully tuned before and after. Everyone throws multiple parts on at once so you really don't know what part did what or they throw a part on and tune with no meaningful baseline to compare it to.
With the H-series and B-series, you can look up a part and literally get info as to where power was made, for a given set-up. I'm surprised their isn't much of any info like this for even bolt on's for the F20 and F22. Gernby has done some, but we need more people to contribute.
#27
Hytech vs J's (force inducted)
https://www.s2ki.com/s2000/gallery/i...-vs-hytechjpg/
https://www.s2ki.com/s2000/index.php...f=142&t=817368
#28
h22tof20- here check this link out man. http://www.importtuner.com/tech/powe...en_header.html pls note that i linked you to the header page, if you go through all of the pages, you'll realize that website did a complete thorough test. to me it's quite impressive being that there was no test pipe in the mix. i'm starting to lean heavily on this header if i decide to stay n/a longer. but eventually i'll go turbo. in any case, i wish they would've threw a test pipe in there coz i bet they would've gained at least another 8whp and plus they had tuning capabilities so they can pick up more hp with a test pipe + tune.
#29
^lol You're using Import Tuner to make your decisions. Their's no way an OEM computer with the OEM test-pipe, will make 12whp from bolting on an exhaust; especially sense it's a dual. The HKS 75mm single only made 6whp. Just by knowing that, I have to assume everything else they tested is BS as well.
From what I've saw, they do this to EVERY part the test.
