Can an oil cooler effect oil pressure? Low(er) oil pressure issue
Something doesn't sound right.. So cruising on the highway ~4k rpms you see 60+ but under load/vtec it drops to 40psi? You shouldn't have such a big drop under load.
Also, like others said, 250 is nothing. Heck, even short trips to 280 on occasional highway pulls wouldn't be a cause for concern.
Maybe I didn't explain well....when I mash the throttle and car hits the vtec crossover point, the oil pressure drops for a sec then comes back up. I assume this is normal, but my concern was that the pressure was too low
The only variable was switching from one type of oil cooler to the other
You do know that oil needs to exceed 212f in order to burn off moisture that gets in it from condensation overnight. 240-250 is a nice oil temp. When you start to worry is when you start seeing it near 300f. That's shut it down time. I ran a Z06 at sebring 2 years ago with a big oil cooler and I would see 310f in 1 hard lap.
I agree, you've got a flow issue. I swapped to a dry sump on my old motor and saw Oil pressure dropping in vtec to 40ish, It was only a matter of min from seeing that the motor promptly put a nice hole in the block. You've got a flow restriction of sorts if your seeing that.
Start trouleshooting at what changed, send an oil sample to blackstone to see if there is high levels of bearing material. Disconnect oil cooler at radiator and loop the lines and see if anything changes, if it doesn't then remove sandwich plate and see if anything changes. If nothing changes then it's in the motor and you've gotta wait for the oil sample to come back (take like 2 weeks) to see if they see anything. If the oil sample comes back fine and nothing changed with the cooler removed completely then I wouldn't worry. But I have a feeling doing one of those 3 things will give you an answer.
The Beauty is looping the lines just mean buying a male to male AN fitting from summit so that's easy, and the blackstone sample is like $30 so that's cheap. so your not spending a bunch of money to try this stuff.
I posted this in the FI section (as that's where I normally hang out), but a fellow member suggested that I post up here for more info....
I recently switched my oil cooler setup. I ditched my Setrab oil cooler in favor of the Jackson Racing radiator/oil cooler combo, now I'm seeing lower oil pressure than before.
Cold start oil pressure is ~60psi
Warm idle pressure is 18-22psi
Both of those readings seem normal/good to me. Where I'm seeing a difference is cruising and under load oil pressure
Cruising oil pressure 60-75psi
Under load/Vtec crossover ~40psi
With the Setrab setup I was seeing 80-95psi cruising
So my big question is....can switching from a bar and plate cooler to a flow thru cooler lower my oil pressure?
On the plus side, my oil temps are staying lower/more consistant
Scott-
Scott-
These heat exchanges sell well because they sound good, but they do not cool the oil in any meaningful way The oil to hot coolant heat exchangers are sadly, snake oil. Unless it's literally a oil cooler integrated within a radiator, you're not seeing a pressure drop or significant oil cooling.
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
