Radiator Cap off
Old 10-29-2016, 06:27 PM
Backmarker's Avatar
Default Radiator Cap off
Idiot alert. I was checking my fluids last night, and topping everything off. Closed everything up, and drove to work the next day.
Got to work, car drove great. Took the time to wash my bay while I had a minute and noticed I had left my rad cap off from last night.... then drove it to work like that. DOH.
I saw the fluid was still at the top (short commute) and figured it was fine. Put the cap on, and drove home at the end of the day. Kept the heat on just to be absolutely sure, and when I stopped at a light - air went cold. Absolutely freaked out and got home just around the corner as the air returned to hot again, and never had the temperature gauge go past normal 3 bars. (AP1)
Got in my garage, cracked the bleeder on top of the engine, and got a little air out. Went to test the heat again and it is now ice cold. So I squeezed the top radiator hose and it went flat and I could hear coolant shoshing around so I am assuming I have air in the system.
Can I just confirm this diagnosis with some smarter people than me? Go get some coolant tomorrow, and just fill/bleed the system and there should be no harm done for my silly mistake........ right?
Thanks guys!
Old 10-29-2016, 07:23 PM
zeroptzero's Avatar
Received 3,390 Likes on 2,461 Posts
yup air in the system.
On the cool down after you arrived at work it would have sucked air into the system rather than sucking fluid from the overflow tank. You must have spilled some fluid during the drive so the air now displaces the fluid that would have been in there before. Do 1 or 2 bleed procedures and see if you can get all of the air out of the system.
Old 10-29-2016, 07:34 PM
Xeon's Avatar
Thanks guys!
yeah bleed it
Old 10-29-2016, 08:37 PM
Backmarker's Avatar
Sure enough! The bleed did it. I will say it lost A LOT of coolant (or sucked a lot of air) as it took about 5 or 6 bleeds to get it done. And I'm still not convinced its all out. Either way, car is holding temp, and coolant is flowing -- so all is well by my book for now.
Thanks you two for keeping me from panicking.
Old 10-29-2016, 10:11 PM
zeroptzero's Avatar
Do you have very hot air coming from the vents in heat mode ? If so that would be a good sign.
Old 10-30-2016, 02:24 AM
Backmarker's Avatar
Yeah, its hotter than it was before! haha I waited to drive it until I got heat.
CrAzYNeSs
12-23-2017 02:13 PM
ryanswhites2k
04-26-2013 03:18 AM
zbrewha863
03-04-2011 09:12 PM
JoeyBalls
07-07-2010 06:22 AM
Spec_Ops2087
05-29-2010 01:22 PM
Quick Reply: Radiator Cap off
