I Screwed Up... Help!
Old 11-05-2016, 05:40 PM
Singitloud's Avatar
Default I Screwed Up... Help!
Well, I thought it would be a great idea to use a pressure washer to get the bugs off my headlights...
So, what can I do to fix this?
Old 11-06-2016, 03:34 AM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
you burned into the plastic and any clear coat on the surface. You need to get one of those headlight polishing kits and get it polished up. There are a number of kits out there that you can find in any auto parts store - 3M, Megs, etc.
Old 11-06-2016, 04:32 AM
Singitloud's Avatar
Thanks. I'll do that right away.
Old 11-07-2016, 04:19 AM
NH_s2k_Guy's Avatar
Careful with those pressure washers! I used one at a car wash and noticed it was starting to remove the paint from the inside lip of the rear fender!
Old 11-07-2016, 06:28 AM
EOE
EOE's Avatar
What seems to have happened to your headlights is, your UV protective coating was "shaved" off with the pressure washer. Unfortunately the only way to get that clarity back is by wet sanding with 1000-1500-2000 grit. Then compound and finally polish. (Megs M105 and M205 will do.) Once you're done, your UV coating will be completely gone and they will haze again in a matter of weeks or months, because of that you'll need to continue applying sealant to your headlights and continue to polish them a few times a year. The only permanent solution (which I've done) is to go to the body shop and see if they have ClearCoat for plastics with UV protection. Have them re-clear your headlights with that solution. It was pure luck on my part that my bodyshop had such product.
Old 12-08-2016, 08:41 AM
Kakarot103's Avatar
Look up headlight restoration on youtube by ChrisFix.
Old 12-15-2016, 04:15 PM
pmptx's Avatar
This.
Basically sanding with progressively finer grits, then clear coat to prevent oxidation
Old 12-23-2016, 10:38 AM
denlin68's Avatar
I have followed chris fix's youtube channel to reclear your headlight .... I did not use any UV clear coat or respray clear coat. my headlight is still nice and clear after 6 months and its parked outside in direct sunlight. It is possible 2-3 years down the road it might get alittle yellow and cloudy .. but a little polish will make it shine again. Highly recommend doing the wetsand procedure. it is like magic!
I have polished my friend's headlight with a random orbiter 2 years ago and it look fine after 2 years. Recent recently a quick hand buff with some polish brought it back to crystal shine.
Old 12-23-2016, 10:50 AM
denlin68's Avatar
worth to wetsand
Old 12-24-2016, 03:58 AM
S2KRAY's Avatar
Use1500, 2500, 3500 sanding bar, compound, polish with 4" foam pad, coat. 20 minutes. Use this process on all of my customers headlights.
ProStreetDriver
07-14-2014 09:29 AM
bam1789
03-27-2010 09:44 PM
DuckieS2k
Inland Empire S2000 Owners
08-25-2009 09:20 AM
jaehoppa
07-14-2007 02:55 PM
StEVEN_s2k
08-27-2005 02:52 PM
Quick Reply: I Screwed Up... Help!
