New 2004 S2000 info from Honda
Old Aug 4, 2003 | 09:33 AM
ngoldberg's Avatar
Default New 2004 S2000 info from Honda
We just received the 04 info for changes in regards to the entire Honda line-up.
I am quoting the release for the S2000.
Changes:
Gear Ratios for 1-4 have been lowered
5th gear almost same
6th gear is a little lower
New Gear Ratio: Low 15.517, 2nd 10.126, 3rd 7.335, 4th 5.750, 5th 4.526, 6th 3.551. This gearing change will increase torque results in better acceleration and better fuel economy.
Exterior Changes:
New Brake Pads, Re-Styled Headlamps, Rear Brake Rotor Size up, Re-shaped Front Bumper, New 17" wheels, Damper and Suspension SPG Refinement, Re-shaped Rear Bumper, Re-styled rear lamps, Drive Shaft Change, Propeller Shaft Change, dual Mass Fly wheel, Tail Pipes.
Interior Changes:
Deeper Sculpted Doors, New Gauge Cluster, Re-styled steering wheel, Reshaped Roll (Where the start button and radio controls are located), restyled aluminum finish (dash).
Color:
Drop Spa Yellow Add Rio Yellow. All Red Interior to Red/Black.
That is all we have for now. Our District Manager is coming in on the 11th to tell us more and I hope show us actual pictures.
Neal
Old Aug 4, 2003 | 09:43 AM
00S2KFAN's Avatar
When are they supposed to start hitting the showrooms?
Old Aug 4, 2003 | 09:46 AM
ngoldberg's Avatar
We were told October by our district Manager 2 months ago and I have'nt been able to order one yet, so that seems acurate.
Neal
Old Aug 4, 2003 | 09:54 AM
shockwave667's Avatar
This seems very accurate being very similar, but more detailed then the other rumors. Thanks for the tips!
RiceBurnerTX's Avatar
So does that mean no new engine? Just new gearing?
Old Aug 4, 2003 | 09:59 AM
PedalFaster's Avatar
[Edit: I posted incorrect numbers is this post by mistake and started an unjustified hullabaloo.]
Anyway, I'm dying to see the new car.
Steve
Old Aug 4, 2003 | 10:03 AM
ngoldberg's Avatar
Like I said, everything I put on here was a direct qoute. The engine is going from a 2.0 liter to a 2.2 liter.
Neal
Old Aug 4, 2003 | 10:32 AM
Elistan's Avatar
[QUOTE]Originally posted by PedalFaster
[B]I don't doubt your info, but the gear ratio numbers sound rather odd, and don't seem to jive with the written info on the gearing changes.
Old Aug 4, 2003 | 10:54 AM
Originally posted by Elistan
Steve, I don't have any of the numbers to crunch myself, so could you check if you took the secondary reduction gear into account or not?
My numbers are potentially suspect, since I just found them on the web. I have no idea if there should be a adjustment for the secondary reduction gear; I couldn't find stats on this for either the current or the new car.
It strikes me as weird that Honda would combine lower gear ratios with a torquier, lower-revving engine; my guess is that "lower" in this case means numerically lower (i.e. taller). Wait and see, I guess...
Steve
Old Aug 4, 2003 | 11:00 AM
STL's Avatar
STL
[QUOTE]Originally posted by ngoldberg
[B]
Changes:
