Emanage ultimate wont connect to windows 7 64 bit
Old 07-10-2013, 05:09 PM
D-Clem's Avatar
Default Emanage ultimate wont connect to windows 7 64 bit
Basically im running windows 7 64 bit on parallels on my mac, I use it to tune k=pro just fine. Well I recently acquired emanage ultimate. I downloaded all the latest software and the program works perfect, just when I plug in the usb, it tries to donwload the drivers and it fails every time. Anyone have ANY idea on how to get it running?
Old 07-10-2013, 05:38 PM
s2000ellier's Avatar
install the GMU driver that is in the installation folder
Old 07-10-2013, 05:41 PM
D-Clem's Avatar
I dont have an installation folder, i have a driver folder and i installed it, apparently from what I'm reading it is not compatible with 7 but somehow people are running a virtual version of xp inside it, i'm just not sure how
Old 07-11-2013, 08:34 AM
D-Clem's Avatar
I got it running. Just created a whole new virtual machine running XP. Magically it works, I guess I confirmed it will not work on 7.
Old 07-23-2013, 05:24 AM
spets's Avatar
it WILL work on 7, just not on 64 bit.
Also, you need to have a USB 2.0 port. I've found that USB 3.0 ports do not work well with virtual machines, at least not VMWare player, Virtualbox, or the Microsoft virtual PC. I've had to resort to my older laptop that has some USB 2.0 ports in order to get the emanage to work on a Windows XP virtual machine inside Windows 7 64-bit.
Old 07-31-2013, 11:16 AM
james0933's Avatar
Does emanage work with the newest windows?
Old 08-04-2013, 10:45 AM
spets's Avatar
as long as you run it in a 32bit virtual machine and have some USB 2.0 ports available, it should.
stack
06-24-2013 03:56 PM
crowebeth
03-14-2010 01:06 PM
Shftat9k
11-08-2007 11:39 AM
ChefJ
05-19-2007 07:16 AM
SoCalIsMyLife
08-10-2006 04:57 PM
Quick Reply: Emanage ultimate wont connect to windows 7 64 bit
