HELP needed please - loose harness wire to AEM EMS 2
I have a KW SC kit that I didn't install. I bought an alloycraft EMS bracket and went to install it. In the process of pulling the 3 harness connectors out of the EMS I may have pulled a wire out of the connector.
I say may have because I was pretty careful prying the connectors out of the EMS without tugging on the wires. I used a flat-blade screwdriver to pry. Anyway, they popped out and then I noticed this loose white wire. It looks like it used to go in the blue connector.
Also, my AEM UEGO WB gauge has a white wire that goes into the blue connector.
Here are pictures. Does the white wire (the loose one with the silver pin on the end need to be going into a connector? If so, where does it go and do I just slide it in?
Thanks
[attachment=79793:20150523_160500.jpg]
[attachment=79794:20150523_160702.jpg]
[attachment=79795:20150523_160651.jpg]
Thanks
See my post in the same thread you started in the FI section.
https://www.s2ki.com/s2000/topic/112...-to-aem-ems-2/
Chiung
05-23-2015 02:41 PM
sbrodacz
04-03-2009 08:29 PM
