SOS Supercharged, Lean out at high rpms
#21
Heres my high speed fueling (top) and timing (bottom)
This is before I changed anything, as you can see, the fuel tables were PUMPED in the area that were showing the lean condition. The highlighted area is the highest the car sees.
#23
Are you running normal 91/93 octane. There is no way you can max out id1000 or a wallbro 255 on straight pump fuel. Generally on stock fuel pressure 1000cc injectors are good to about 600whp on gas 93octab/c16/race gas and about 470-500whp on e85. A wall to 255 maxed out at about the same or a little bit higher than 1000cc injectors. Maybe you should start thinking about a return fuel system.
#24
It's "sorta" a return system now with the surge tank, it has an adjustable fpr on it after the pump, before the rail, so if I run out of duty cycle, I can just bump the pressure for more head room. I'm running ~ stockish pressure and my duty cycle is now about 70% at 13 psi, 8500 tuned to 12.0.
The leaning out was caused by faulty wiring, the supplied pinned harness from radium wasnt making a good connection. I repinned it and electrical taped the hell out of it to keep it from moving and my issues have disappeared.
CoolGuy094
01-26-2014 03:54 PM
