SOS Supercharged, Lean out at high rpms
Old 02-14-2016, 12:48 PM
  #21
liquid_helix136's Avatar
Heres my high speed fueling (top) and timing (bottom)
This is before I changed anything, as you can see, the fuel tables were PUMPED in the area that were showing the lean condition. The highlighted area is the highest the car sees.
Attached Thumbnails SOS Supercharged, Lean out at high rpms-fuel.png   SOS Supercharged, Lean out at high rpms-timing.png
Old 02-26-2016, 07:25 AM
  #22
Janus00's Avatar
This post was a great read, glad you got everything worked out.
Old 02-26-2016, 02:09 PM
  #23
riceball777's Avatar
Are you running normal 91/93 octane. There is no way you can max out id1000 or a wallbro 255 on straight pump fuel. Generally on stock fuel pressure 1000cc injectors are good to about 600whp on gas 93octab/c16/race gas and about 470-500whp on e85. A wall to 255 maxed out at about the same or a little bit higher than 1000cc injectors. Maybe you should start thinking about a return fuel system.
Old 02-27-2016, 12:28 PM
  #24
It's "sorta" a return system now with the surge tank, it has an adjustable fpr on it after the pump, before the rail, so if I run out of duty cycle, I can just bump the pressure for more head room. I'm running ~ stockish pressure and my duty cycle is now about 70% at 13 psi, 8500 tuned to 12.0.
The leaning out was caused by faulty wiring, the supplied pinned harness from radium wasnt making a good connection. I repinned it and electrical taped the hell out of it to keep it from moving and my issues have disappeared.
Old 02-27-2016, 11:08 PM
  #25
s2k manic's Avatar
glad you got it sorted i hope i can figure out my issues soon
CoolGuy094
01-26-2014 03:54 PM
stantaur
04-22-2013 11:00 AM
TonysMI4
08-03-2011 05:56 PM
s2k_suprchrgd
07-29-2010 05:09 PM
duff0000
06-05-2006 01:51 PM
Quick Reply: SOS Supercharged, Lean out at high rpms
