Timing Chain Tensioner HELP!
I bought a new TCT and proceeded to start the removal of the old one.
It took some tugging and twisting to remove the old one. When it broke loose, it all came out very fast and parts fell out of the assembly. I found everything except for the piston!
Is it possible for the piston to fall inside the engine? Is there enough room for that to happen?
Anyway I installed the new one. I rotated the engine a little to see if there was a problem. I then bumped the starter a few times. Finally I started the engine at idle.
I am afraid to drive it. If that piston is in the chain case I have a big problem.
Again, is it possible for the piston to fall in?
Thanks,
Jim
Thanks,
Jim
I would pm Billman250 he would be best to answer that one for ya and offer some advice. It's hard to tell from the shop manual but does the base of the chain case lead into the oil pan ?, if it does and it ended up in the oil pan it might be relatively safe in there.
I pm'd Billman250 thanks for the suggestion.
Jim
yeah he knows these engines best. Did you compress it before attempting removal , if you did the part might be recessed into the TCT, if not then that was likley the reason why it was difficult to remove.
seen this happen once. if you are lucky you can get a magnetic retriever and see if you can get it out that way. it may be a pain in the butt, its better than disassembling the block.
If they are gonna break it down anyway I figure I should make it worthwhile.
I have 168000 miles on the car. I don't know how long the chain is supposed to last. The manual says nothing about it.
It's laying on the frame. There is not room for the new piston if the old one is still there. I had this happen a couple weeks ago and I used a mirror to check what was remaining.
Failure to compress the new tct prior to installation will cause problems but not prior to removal.
Originally Posted by jelanier,Nov 21 2010, 07:06 PM
I don't know where it would go. If I have my timing chain replaced, they should be able to find it if it is there right?
Sounds like Sidways (ABOVE) may be onto something, it may have popped out and is laying on the frame or in some tight spot outside of the engine. For peace of mind get a long flexible magnet and try to fish around inside the timing case just as insurance.
