MAD 282km!
MAD 282km!
there is a not so good video of me during attiki odos 13:00 o 'clock. i thought that it will be good if i video the speedometer but a car stopped me in front.... if you see the video at the beggining u will see 282km!! and then i press tha brakes...
soon i will record the 290km reached a couple of days ago at night.
stay tuned!
http://briefcase.pathfinder.gr/download/np.../0/5ACB0002.mp4
stay tuned!
thats really weird. you have 4.44 final gear. with the stock 4.1 gears you have 283 km @ ~9.000rpm. 4.44 gears limit you @ 255-265km/h. Did you increase your rev limiter?
O Νίκος όχι μόνο έχει αυξήσει το rev limit αλλά ενώ έχει αλλάξεςι το FGR σε 4,44 δεν έχει πειράξει το γρανάζι του κοντερ/χιλιομετρητή (they call me yellow box) και φοράει 18αρες ζάντες (αλλο βήμα) με άλλα λόγια το κοντερ δείχνει στο περίπου. Κάθε αλλαγή FGR αλλά και ζάντας - ελαστικού απαιτει recalibration αλλίως γράφει έως και 10% περισσότερα δηλ στα 280 περίπου η ταχύτητα είναι 255 περίπου και τα 290 που έχει δει τελική αντιστοιχούν περίπου στα 265 + λαμβανομένου υπάψη και του αεβασμένου κόφτη Rough calculations of course
8800 revving normal mode 281km
9500 revving normal mode 303,3km
with the 4,11 normal 281km
with the 4,44 normal (8% decrease) 258,5km
now with the 9500rpm rev limiter
with the 4,11 normal 303,3km
with the 4,44 normal 279km
so back to basic vag.
need to learn maths again.
if you consider my wheel diameter the normal mode is 225/50/16 that is
diameter 631,4mm and the new size 225/40/18 diameter 637,2.
that is 0,9% more km that the stock ones.
also check:
http://www.miata.net/garage/tirecalc.html
to conclude if we add to the 279km +0,9% the real km are 281.5 km!!!!!!
the total km i have seen on the dyno is 297km.
soon you will see these km.
also check:
Take an EVO magazine and see at the back section of all time classics, wich cars can go over 290km/h...
There is no way, a normaly aspirated S2000 can go over 280km/h.
Not on a dyno, not what the speedometer shows, only on the road with a GPS and laptop.
Fortunately the S has the aerodynamics, but it lacks power and torque.
Nikolaki, my darling!!
Apo 4,1 se 4,44 = 8,5% difference in reading
Logw allagis diastasewn = 0,9 difference in reading
Ara total approx 9,5% difference in reading
Which means that when your speedo reads 282 km it reads more by 9,5% which equals to approximately 255 km as I said
Anevarmeno rev limit den allazei tous ypologismous tha deis 290 i kai 300 !!! alla ta xiliometra tha einai overstated by 9,5%. Mono me GPS tha ksereis akrivws poso pigaineis alla whats the point?? As evlepa kai egv 300 sto konter mou (alitheia mporei na diavsei toso i stamataei sto 299) kai ti sto kosmo!!!
egw apla lew oti MHXANIKA me 4.44 den mporeis na pas 280.. tora sxetika me to koder den pernw kai orko, giati isos na diavazei apo to diaforiko opos sta prostokinita, opote kai 5 final gear na valeis pali swsta tha diavazei. den kserw apo pou diavazei, isos apo to kivotio.(dropi na min kserw pou diavazei )
diavazei apo to kinwtio.
DEAR VAG.
exases ena math rule. eimai 0,9%+ sto diameter. ara einai 8,5%-0,9%=7,6%.
am i right?
efoson exw megalyteris diametrou elastika.
DEAR VAG.
am i right?
Dear NPart
You are right 0,9% should be subtracted not added my bad! Even so the difference is a mere 5 km/h ie instead of 255km/h the speed is 260km/h when the tacho indicates 282. Even so you told me that max speed the tacho is capable of indicating is 297, so there goes my dream of a 300+ km/h S2k dash reading Never mind U will be seeing a lot more than what we do and this is a plus
PS What are you doing in front of your PC man, you should be in the garage meshing with that diferential!!! Don't let me down
