Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Lowering question:
Old Aug 12, 2010 | 10:04 AM
S2KMiyo's Avatar
Default Lowering question:
So I'm considering getting a set of Spoon Sports progressive springs (cuz I'm clearly too poor for J's Racing coils ), and I was wondering how a 1" (25mm) drop will affect tire wear. Does anyone have their car lowered just a bit? How is your experience?
Thanks!
Chong
Old Aug 12, 2010 | 10:30 AM
Boofster's Avatar
I don't know anything about that kit but 1" does nothing to your tire wear as long as you get an alignment after install. 1" is the most common drop. It's
Old Aug 12, 2010 | 10:45 AM
Northbay's Avatar
get it aligned, there won't be a difference in wear.
Old Aug 12, 2010 | 11:59 AM
adrs2k's Avatar
Agreed. And it is worth saying that camber is not what wears your tires unevenly, it is toe. Excessive toe will cause the tires to scrub while rotating. Yes, at some point running extreme amounts of negative camber can wear the inside of your tires faster, but it is going to take "extreme" amounts to do so. To put it in perspective, i run -2.0 front camber, and -2.5 rear camber, and have done so on my last set of tires, and my current set of tires. I get PERFECTLY even tire wear. Make sure your alignment is good, and your tire pressures are correct, and uneven tire wear is a none issue!
Old Aug 12, 2010 | 12:27 PM
S2KMiyo's Avatar
I see~ I didn't even think to realize that lowering the car not on changes the camber, but also the alignment. Oy~
If you guys know of any good alignment shops at a good price, please hook a brotha up.
Thanks!
Old Aug 12, 2010 | 01:43 PM
9KRDLIN's Avatar
SOS
Old Aug 12, 2010 | 04:58 PM
dat boi's Avatar
Shuman's is who I've always used. It was SOS's old contact, and SOS as well as Network, but I've never tried the latter.
Old Aug 13, 2010 | 10:03 AM
S2KMiyo's Avatar
Originally Posted by 9KRDLIN,Aug 12 2010, 01:43 PM
SOS
Sweet! Will always support Geoff over there!
LT1
Jul 6, 2016 02:51 AM
Bronxbomber9009
May 7, 2009 01:25 PM
eddies2k
Apr 21, 2009 09:56 AM
kylemonster85
Apr 29, 2008 12:30 PM
baldy74
Jul 9, 2002 04:27 AM
