Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
MAF sensor
Old Sep 8, 2010 | 01:27 PM
-=Theoscion=-'s Avatar
Default MAF sensor
Hey all:
I am still running lean on the Lotus and I'm really starting to think its more than just the exhaust. I wanted to know if anyone knew how to check a MAF sensor to see if it is failing for failed, and if they can let me know how to do the check.
Any help is greatly appreciated.
Thanks everyone!
Old Sep 8, 2010 | 01:28 PM
9k All The WAY's Avatar
Borrow mine? If there even the same...
Old Sep 8, 2010 | 01:34 PM
9KRDLIN's Avatar
totally different. you would need to check the values with an OBD2 scanner, and see what it is saying. It may be your o2 sensor reading rich, which would cause your ecu to lean itself out. You could also clean it which is easy, to see if that helps.
Old Sep 8, 2010 | 05:39 PM
averageJoe's Avatar
How do you know it is running lean?
Or what makes you think it is lean?
you just need a voltage meter to check if it is working properly in accordance with the service manual.
Old Sep 8, 2010 | 09:19 PM
I constantly have P0171 for a check engine light. Also, I have detonation unless I'm running race fuel.
Old Sep 8, 2010 | 09:53 PM
averageJoe's Avatar
drive your car like grandma for 2 months, save the money you would have spent for pump and race gas and buy a wideband o2 sensor.
it will pay you back in the long run through issues like this and gasoline savings, and you can remove it if you sell the car.
this is the first thing anyone should buy for a car, even if it is a brand new 2011 economy smart car. no need to have an afr of 14.7, when it runs fine at 16.1
seriously though, you'll have to bust out the multimeter to know exactly what is going on.
Old Sep 9, 2010 | 08:43 AM
9KRDLIN's Avatar
sounds like a common problem, check out the TSB on the first link
http://www.lotustalk.com/forums/f157/exige...de-p0171-48132/
http://www.lotustalk.com/forums/f171/ecu-g...ow-p0171-56301/
http://www.lotustalk.com/forums/f101...e-ideas-85387/
FrontRowForward
Sep 22, 2013 11:46 AM
JuicedS2K
Jan 5, 2011 05:59 AM
milkman2089
Jan 27, 2010 07:39 PM
s2k_jay
Dec 28, 2006 12:58 AM
Malu59RT
Dec 27, 2003 10:25 AM
