Check Engine Light
Old Sep 22, 2013 | 09:22 AM
FrontRowForward's Avatar
Default Check Engine Light
Looking for some help/advice please.
The CEL has popped up again, I've plugged my C Reader V in and it's thrown up the following 2 fault codes
1. P2A00 - O2 sensor circuit range/performance (bank 1 sensor 1)
2. P2A00pd - O2 sensor circuit range/performance (bank 1 sensor 1)
I'm assuming this is the primary sensor before the cat? If so I only replaced this sensor less than 2 years ago. Is it a common issue?
Would this be the correct replacement http://www.ecolambda.co.uk/main/ecos...item=250-54023
Thanks.
Old Sep 22, 2013 | 11:46 AM
richmc's Avatar
Lamda sensors should be considered a consumable item, but around 5 years not 2, unless you are doing mega miles.
dls91
Oct 15, 2015 10:22 AM
JuicedS2K
Jan 5, 2011 05:59 AM
McMuffin
Dec 15, 2008 11:55 AM
01SSAP1
Sep 6, 2007 07:27 PM
