Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
power gains
Old Sep 7, 2006 | 01:38 AM
RogerHinga's Avatar
Default power gains
okay.. when i first got my s2k i promise myself to keep it stock.. but lately i want more power out of it.. how much gains do people normally make with intake, exhaust and header?
Old Sep 7, 2006 | 06:16 AM
Gloffer's Avatar
Less than 10 HP. Biggest gain would probably be from the weight loss on getting rid of the stock exhaust. Stock exhaust weighs 50-55 lbs, while the heaviest single is ~20 lbs. and the lightest titanium single is ~12 lbs. Save your money for a supercharger if you really want to add power.
Old Sep 7, 2006 | 06:30 AM
silvershadow's Avatar
And you really have to research the ones that give power gains. Some of the aftermarket pieces claim power gains, but in actuality reduce maximum horsepower.
Look for those aftermarket pieces that have been tested by someone on the site, preferably with a before and after dyno run.
Old Sep 7, 2006 | 08:05 AM
replica's Avatar
If money's an issue at all, gears would be cheaper than I/H/E, and would probably be much more noticeable.
Old Sep 7, 2006 | 08:27 AM
turbo_pwr's Avatar
The problem with gears is the labor cost involved in installing them properly. If you are to go with gears, I would swap out the LSD at the same time, go with a 2 way since you like to drift.
But as far as power, you have a couple of choices. The New England guys have been able to get some decent gains with the Greddy Emanage Ultimate.
Otherwise simple I/H/E won't yield anything major.
Old Sep 7, 2006 | 11:20 PM
CypherAZ's Avatar
test pipe.
Old Sep 8, 2006 | 04:03 AM
RogerHinga's Avatar
i was also thinking about going with a supercharger but the thing is i have never really delt with force induction on a honda when it comes to emission. I know with my silvia all i have to do is retard the timing throw a cat on and i will pass easy... how hard is it to pass emission with a supercharger or a turbocharger? I'm not looking for anything crazy either just about 40-50whp if i do boost..
Old Sep 8, 2006 | 05:38 AM
turbo_pwr's Avatar
The Comptech and Vortech kits are both Emissions Approved, so you should have absolutely no problems passing with either kit. The Comptech is tuned less aggressively then the Vortech so it's the safer bet. Unfortunately it doesn't come with an aftercooler which would be handy in the hot temps out here. The Comptech will net you closer to 80whp and Vortech usually nearer to 100whp. That's based on the dynos people have posted over the years.
Old Sep 8, 2006 | 06:35 AM
Zonie's Avatar
The Comptech kit is now available with an aftercooler. I'm leery about the Vortech kit after Wil got stranded in Greer (oil leak from a brass fitting).
Old Sep 8, 2006 | 06:50 AM
turbo_pwr's Avatar
I know it's available but it's not included in the base kit. Buying the kit is $ lot more then just getting the Vortech.
