Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Question on colored lug nuts
Old Aug 11, 2010 | 12:38 PM
watchdogd's Avatar
Default Question on colored lug nuts
I know that some manufactures make different colored lug nuts for aftermarket wheels. Some are annodized but I thought that some were also powdered but not sure.
The place where I had my wheels powdered is coating one of my lug nuts white free of charge as a sample to see how it holds and looks. I'm guessing it might not but worth the try.
Does someone know offhand how the aftermarket colored lugs keep their color so well? Are they dipped in some other material to keep them from chipping ?
Thanks,
Old Aug 11, 2010 | 01:17 PM
Boofster's Avatar
I don't see how anything painted would hold together when 80lb/ft of pure scratching power is applied to it
Even anodized scratches off eventually. The burned titanium look seems to be holding 100% though.
Old Aug 11, 2010 | 01:23 PM
1FastS2k's Avatar
My old Muteki open ended lugs are more chrome than red now, I think they are anodized but I'm not sure. I just put on a set of black Muteki closed ended ones, we'll see how they hold up.
Old Aug 11, 2010 | 01:26 PM
Nate4635's Avatar
The red rays anodized lugs look pink after a week in the AZ sun
Old Aug 11, 2010 | 01:33 PM
9KRDLIN's Avatar
Snap-On, Matco, etc all make sockets with a plstic inside that protects lugnuts. So you can apply an even amount of pressure, and still protect. The only place that would probably even use it is WSI though. Hit them up
Old Aug 11, 2010 | 02:12 PM
jefferyg32's Avatar
Remember 98% of aftermarket lugs will only work with aftermarket wheels!! The ball seat is different between aftermarket and OEM!
Also remember if you powdercoat the lugnut the 3/4 -19mm size will probably not work anymore as now the lug will be oversized.
Also remember if you paint them, after you remove them once or twice they will become chipped and distorted in color and finish.
Also remember to have your pets spade or neutered!!
Old Aug 11, 2010 | 02:23 PM
Boofster's Avatar
I'd like to own a 19 and a 17 of those.
Couldn't find it on the SnapOn website.
Old Aug 11, 2010 | 02:26 PM
adrs2k's Avatar
If you must have something different, buy OEM CR lugs. They are black, which imo, would look the best on your red wheels. Painting OEMs will not hold up at all.
Old Aug 11, 2010 | 02:39 PM
Nate4635's Avatar
I found these. I think I might order this set.
http://www.tooldiscounter.com/ItemDisplay....ogle&kw=AST7835
13/16, 7/8 inch and 17, 19, and 21 mm
This socket set features protective sleeves and internal plastic inserts that prevent scratching of wheels and decorative lug nuts.
Hollow design creates room for removing longer bolts by pushing out plastic insert.
Blow molded case for easy storage and transport.
Case dimensions: 10 1/4 x 6 1/4 x 1 3/4 inches
Net Weight: 5 pounds
Old Aug 11, 2010 | 03:17 PM
watchdogd's Avatar
Hmm that sounds like a good option.
So here is the final result. Not an "Epic Fail" but clearly you can see the scuffs.
Maybe the plastic covers would help not sure though with 80lbs of torque.
