Ark-La-Tex S2000 Owners Covering Arkansas, Louisiana, and East Texas
VSA/Check Engine Light on
Old Mar 31, 2010 | 09:47 AM
  #41
ans2k's Avatar
i mean diff and tranny as well.
Old Mar 31, 2010 | 10:08 AM
  #42
mr flannery77's Avatar
No, I have not checked those, but I'll add it to my list.
Old Mar 31, 2010 | 12:44 PM
  #43
ans2k's Avatar
wait, u have 40K miles and you havent changed those fluids yet???!!!!
Old Mar 31, 2010 | 03:26 PM
  #44
icemans2k02's Avatar
It's not bad if he hasn't changed the fluids. Unless the diff or transmission is busted contanaments don't flow through it since they are sealed. It's just good practice to change it if you track the car as the consistent amount of heat breaks down the oil over time.
Old Mar 31, 2010 | 03:38 PM
  #45
spets's Avatar
Not just the heat, but the gears meshing will shear down the oil. Recommended change interval is 30k, but most people seem to change them around 10k-15k.
Old Mar 31, 2010 | 03:59 PM
  #46
ans2k's Avatar
i thought the diff needed to be changed out at least every 15K?
Old Mar 31, 2010 | 05:01 PM
  #47
Ch0pper's Avatar
Originally Posted by mr flannery77,Mar 30 2010, 12:29 PM
Could it be linked to a problem w/ the LSD? I have noticed a kind of "grinding" sound a few times, similar to the grinding you hear when you miss a gear. It's only been when turning a corner out of a complete stop, and giving it a semi-healthy amount of throttle.
Again, it's not a constant thing, but it's definitely happened more than a couple of times (and I can't feature it being a "good" thing).
Interesting suggestion about the LSD... The grinding sound could be semi-normal as I hear it from time to time even after having gearsets 1-4 replaced (but thats abnother topid since I was having synchro issues and too often grinding in gears 1-3)
Wouldn't worry so much about it.
I would recommend a tranny and diff change. There are some good DIY instructions on the forums although it's pretty basic.
Andrey is right, most people do it every 10-15k miles, I know I do.
As Bobby said too, it's good practice if you run the car hard.
Old Mar 31, 2010 | 05:12 PM
  #48
Thanks Andy. My lack of knowledge for routine maintenance is obviously shining through here. When search is back up and running I'll look up some DIY post. From what I saw in the service manual, it appears to b pretty straight forward.
Old Mar 31, 2010 | 07:10 PM
  #49
spets's Avatar
Yep, hardest part is getting the new fluid pumped up into the fill hole!
Old Mar 31, 2010 | 07:23 PM
  #50
Ch0pper's Avatar
Here ya go:
Tranny Change thread:
https://www.s2ki.com/forums/index.php?act=S...22&t=565855&st=
Diff Change thread:
https://www.s2ki.com/forums/index.php?showtopic=348700
