d1000rr's build
#251
#252
Well...
10 brutal hours later... I replaced the release bearing. For anyone reading this... take my advice and ditch the Competition Clutch Release bearing and replace it with an OEM unit right from the get go.
#253
Dennis , just check the connector on the 02 sensor at the tranny mount location, it may be loose, could be a simple fix as that, lets hope so. Car looks great as usual. pal.
#254
Thanks Joey.
Ya I gotta get back under there and have another look.
I am running a flashpro so I might just disable the o2 sensor and call it a day.
#255
Update with some picture whoring.
Also, had a boost leak... turns out one of the hot side pipes had popped out of the coupler... it was an easy fix. Now I need to get some t-bolt clamps and ditch these worm clamps.
#256
Car is looking great, love the pictures.
#257
Update now that it's almost spring....
A few things I needed to install and a few more things that I still need to install.
I replaced my crappy leaking cusco catch can for a Radium catch can and also replaced the ugly oem coolant overflow tank with the Renegade one.
Also replaced my oem rad with a mishimoto aluminum and capped it off with an HKS rad cap.
Before:
After:
And clean again....
Still need to install a few things. I have a Renegade brass shift bushing that I needs to go in and I also need to change the oil/filter...
Before:
After:
And clean again....
Kenny_Stang (04-27-2018)
#259
Car looks great
I also have the renegade bushing that i have had not installed since iono August. haha
But everyone also says to replace the plastic part on the shifter as well while your at it.
