Automotive builds Got an automotive build you want to want to document? Post it here!
d1000rr's build
Old 09-12-2017, 08:25 AM
  #251
d1000rr's Avatar
Originally Posted by Dreaming_S2k
Supercharged is so much fun. Just enough power to do some fun FI thangs, but not so much that you break trans and rear diffs all the time.
Looks amazing as always!
For the most part it is super fun ...
Old 09-25-2017, 09:10 AM
  #252
d1000rr's Avatar
Well...
10 brutal hours later... I replaced the release bearing. For anyone reading this... take my advice and ditch the Competition Clutch Release bearing and replace it with an OEM unit right from the get go.
Old 09-28-2017, 05:21 PM
  #253
zeroptzero's Avatar
Received 3,385 Likes on 2,456 Posts
Originally Posted by d1000rr
Well...
And now I'm throwing a code.... ugh.
Dennis , just check the connector on the 02 sensor at the tranny mount location, it may be loose, could be a simple fix as that, lets hope so. Car looks great as usual. pal.
Old 10-03-2017, 05:59 AM
  #254
d1000rr's Avatar
Thanks Joey.
Ya I gotta get back under there and have another look.
I am running a flashpro so I might just disable the o2 sensor and call it a day.
Old 10-23-2017, 01:41 PM
  #255
d1000rr's Avatar
Update with some picture whoring.
Also, had a boost leak... turns out one of the hot side pipes had popped out of the coupler... it was an easy fix. Now I need to get some t-bolt clamps and ditch these worm clamps.
Old 10-24-2017, 05:03 AM
  #256
Kenny_Stang's Avatar
Car is looking great, love the pictures.
Old 04-13-2018, 12:01 PM
  #257
d1000rr's Avatar
Update now that it's almost spring....
A few things I needed to install and a few more things that I still need to install.
I replaced my crappy leaking cusco catch can for a Radium catch can and also replaced the ugly oem coolant overflow tank with the Renegade one.
Also replaced my oem rad with a mishimoto aluminum and capped it off with an HKS rad cap.
Before:
After:
And clean again....
Still need to install a few things. I have a Renegade brass shift bushing that I needs to go in and I also need to change the oil/filter...
Old 04-26-2018, 11:29 AM
  #258
d1000rr's Avatar
Kenny_Stang (04-27-2018)
Old 05-01-2018, 10:07 AM
  #259
RussianHammer's Avatar
Car looks great
I also have the renegade bushing that i have had not installed since iono August. haha
But everyone also says to replace the plastic part on the shifter as well while your at it.
Old 01-26-2019, 02:12 PM
  #260
Anualmix's Avatar
Saw your topic selling the Custom Roof Box and had to check your project. Really Really well done!
msdunkel
05-14-2018 01:35 PM
WhyZed
10-12-2008 06:37 PM
mzk784
09-07-2008 12:48 PM
comets
05-16-2005 05:38 PM
van
10-23-2003 06:41 AM
Quick Reply: d1000rr's build
