M3TOS2K (Mugen, J's Racing, Spoon, ASM)
Hey Mark, sorry to see this happen to you man. Like others have said at least your ok, I still cant believe this is your first spin ever. I dont know if you recall when we spoke at Sonoma about the re71r feeling loose hard to find the limit. Like I had said when they let go they slip out from under you quick. Not as progressively as the rs3 would. I hope you can sort everything out and get her back on the track
your a beast behind the wheel
Thanks guys. I share because I'm here to learn like everyone else.
Here's 2 laps from the time attack session which was before the last time I went out and ended up crashing. No personal best, just consistent 1:45's. I know I can do better, but I've lost a lot of confidence at turn 6. I looked at my data and noticed I'm braking way earlier than I used to in the past.
https://www.youtube.com/watch?v=5ZRtOUWl7Fk
Sorry to hear about this man, I really think you are still great driver. Not really sure what happened here but I hope you come back bigger and better than ever. The main thing is not having any frame damage. The cosmetic stuff can be repaired. Best of luck to you !!
33-34 psi. It was a very hot day for Laguna. Temps were in the mid 90's and track surface temp in the morning was 110-115 so I'm sure it was much hotter in the afternoon.
Originally Posted by jst2878' timestamp='1475634887' post='24076944
255 re-71's on a 10" rim? What was your pressures? That thing will be up and running in no time, honda still makes all those parts. Glad youre ok
These tires like to spike in temp. With those outside temps you couldve been much higher than that. Plus the narrow width of these tires and the 10" rim leaves not much room for mistakes. Id like to try those trofeos out
I didn't know you had a build thread! I've always been a fan of your car and how you drive at the track. Sorry to hear about your wreck but I just can't wait too see the car back! It's going to be great! My friend also had a similar spin at that same turn, everything exactly the same. Turns out that one of his rear top hats was cracked.
