Slowteg- Build thread
I tried PMing you, but it said you could not receive them for some reason.
I am thinking about purchasing a set of TSW Interlagos 17x9 wheels with 255/40R17 tires all around.
Two questions:
-Do you know if this will cause any fender rubbing?
-What center caps did you purchase for your wheels to give it the OEM looks?
Thank you in advance!
Two questions:
In terms of fender rubbing, I did a light roll on my front fenders to play it safe. Not sure if I mentioned that in the build but the tabs for the fender are rolled up so they don't catch. I really wanted to avoid rolling my fenders if at all possible, but I opted to do it to play it safe as a mangled fender is worse than a light roll. On hard cornering at the track I didn't want to risk it. The rear fenders are untouched.
The center caps are the TSW center caps with a Honda "emblem" over top of them I got off ebay. I measured the inlay with a caliper and found the closest one that'd fit on ebay. They feel like they have a bit of metal in them and have double sided stick tape to stick to the TSW center caps. I ordered a few sets (they're cheap) and used the one that fit the best. I honestly dont know which one I purchased and don't even know if they're sold anymore so I'm sorry I can't provide a link. Best bet is measure the center cap and check ebay. Hope that helps.
Good read on heel toeing. For years and years (and I am still not perfect at it) I struggled to heel toe. I tried the traditional method you see everyone doing with the toes on the brake throwing your foot up in the air and blipping the throttle with your heel. I also picked up the pedal extender from SRP and have begun using the rolling the foot method with my heel still on the ground. I tend to use my little toe and the one over (roughly) on the brake the other 3 toes on the gas. I recommend it for anyone who has the same issues.
Oh ya, regarding the track.. my life has been entirely pre-occupied lately by the kids (with the exception of some house projects), but I'm looking to do a couple track days in the next couple months. I will just post after the fact since it's stupid to say I'm going to do XYZ and then it comes and goes and nothing happened. FYI, the TNIA events at Dominion were cancelled for the foreseeable future or else I'd have tried the new track out.
Two questions:
Two questions:
-When you mention the rolled fender tabs, Am I correct to assume you are you referring to the front fender tabs as discussed here: https://www.s2ki.com/s2000/topic/102...ling-tips-etc/
-I, too, would like to avoid any fender modifications. I am on completely stock suspension on my AP1, including stock alignment and tires/wheels. I do not plan on running any spacers on the wheels. I'm debating moving down a tire size to 245/40R17 in order to provide a bit more confidence in not rubbing. Moving to 245 also seems to open up the options in tires and cuts off a good $180 on a set of 4 tires (RE-71r). I plan on getting an alignment with more aggressive camber to help grip on the track and provide even more fender clearance. Any thoughts or advice (particularly on 245 vs 255)?
Thanks about the garage.. I had dreams of a lift but unfortunately it's just too damn tight and probably not worth it for an in ground one..
Again, thanks for your insight, very much appreciated. Didn't mean to thread jack your thread! Haha.
Mostly just hard parking lately.
I'm signed up for next Friday at Dominion. Been too damn long. Nice to get out on track and try out the new track even though the curbing sucks and it looks like driving down the Jersey Turnpike in spots with no/little runoff. You comin?
Just gotta swap the pads and maybe I'll change the brake fluid.
Not in the area any longer now that Dominion is open. I'm actually really disappointed with that track. Your turnpike description is pretty accurate for some parts of the track. It looks like a place that would be hard to really push to the limit if you intend to bring it home in one piece. That said I'll be looking forward to seeing some footage from it
