Proton flush mounts install help!
Ok, I'm having a slight problem here.
I am trying to setup my signals for strobe, and when I do, the way I wire it makes them stay on no matter if the signal button is on or off.
Here is my little diagram:
The weird thing is if I take the yellow wire out of the equation, the signal operates normally but without the strobe that I want.
What have I done wrong?
Thanks!
Thanks!
I know you said you figured it out but I thought I'd post this in case you wanted to change the blink or something
RED wire goes to OEM running light wire
Black wire goes to OEM ground wire
now you connect one or two of your remaining wires to the OEM blinker wire depending on the effect you want
Normal blink you connect Orange wire ONLY
For Strobe blink connect Yellow wire ONLY
For Fade in and Fade out blink connect BOTH Orange & Yellow wires
You also can check out there web site Proton Web Site but its just going to tell you what I just told you
Good luck hope this helps
TerminatioN
03-16-2012 01:32 PM
