stripped spark plug
stripped spark plug
Hi all I don't post here much but do stop in time to time. Here is my problem. I was driving to work in Benicia from Galt. About 2 miles from work my S2K started to sputter and barly run. I puled off to a gass station and caled for a towe to Concord honda. I just got off the phone with them and they are saying a spark plug came loose and striped 3/4 of the threads in the head. So I dont have the money to fix it right now and have made arangements to towe it to my house (U-haul trailer) where it will sit untill I can find the time to pull the head for repairs.
My question's are
1. Does any one have recmondations. ( I know you don't have all the info yeat)
2. need a machine shop to sleav and tap new threads for spark plug.
3. need a 2.2 piston kit, wile I have the engin open up might as well up grade!!
I have ben looking at the CP pistons at 11.0-1 .20 over. any coments are welcome. And any help.
My question's are
I forgot you name but I do remember you from our RPM meets. You had low miles on your car right?
1. Shad at DA has a rebuilt head you may want to ask him about that. Or you can get a used long block from HAP and just swap the whole motor. Once you find out what the extent of the damage is then you can go from there. If the threads are stripped then head might be useless but once again find out the damage. You know you can check if your MY01 had the sparkplug recall done. I'm not sure what can be done since your car is way out of warranty. See if there is a way the dealer can do a "good faith" warranty if your car DID NOT have the recall done.
2. if it's 3/4 damaged I would not personally trust a helicoil to fix the head. It may be a bandaid but I would hate for the helicoil to give out and see a plug shoot through the hood.
3. Depending on budget and the extent of the damage just buy a used 2.0 or 2.2L long block from HAP or another recycler. If you decide to get a used long block lemme know and I'll try to point you to the right person to talk to at HAP.
Thanks. I am talking to a guy I know from Texas that works for BMW and he was telling me that the sleaving for a new spark plug would hold no problem as long as it was dun right.
Well monday I am going to trailer the car home. and mabe next weak I will have time to start working on it.
I need a manual for working on the S2k know where I can get one.
Just found this great parts site for the S2000 OEM parts
http://www.hondapartscheap.com/southbay/jsp/home.jsp
If you keep that stock and helicoil it then you will probably be okay. If you want to mod get a new head and mod that one.
Good luck bro
Keep us updated.
Well I brought the car home and it is sitting in my gerage waiting for me to have the time to fix it. I have to buy new plugs, Plug wires/connectors and heli coil the head and hope it holds. O and check the cylender for debrie/clean it out. good times >
Will have video and SS soon.
