California - Central California & Sacramento Central California & Sacramento S2000 Owners
Window Seals
Old Dec 22, 2005 | 01:01 AM
Aznous's Avatar
Default Window Seals
Has anyone had a problem w/ the rubber seals on the top right corner of the window? When it rains it dribbles H20 down the inside of my window!
Old Dec 22, 2005 | 04:49 AM
The Gasman's Avatar
Mine only leak a little after a carwash. I think there are some seal restorers that you can rub in that might help.
Old Dec 22, 2005 | 06:19 AM
gomarlins3's Avatar
Never leaked even a drop.
Old Dec 22, 2005 | 02:40 PM
Aznous's Avatar
Must be them 01' models and shit...Mine does the same thing after a full blast of water from the carwash..Also if my S is outside and it has been raining for awhile..
Old Dec 22, 2005 | 03:52 PM
gomarlins3's Avatar
Doesn't it say in the manual not to take our cars through the car wash?
Old Dec 22, 2005 | 06:13 PM
moonsurfer's Avatar
You may want to treat your seals with some shin etsu grease. That will help soften them up and keep them protected. You can get it from handaaccessories.
Old Dec 22, 2005 | 09:05 PM
s2kgirl2k3's Avatar
rubber seals srink a bit when the weather is cold ,, to make them regain there shape and size ,, rub them down with vasoline . not alot but enough for it to cover the rubber ..best to do it when the sun is out , but if you rub some on the seals and then drive with the heater on for a bit ... it will allow the vasoline to soak in to the seal ... works great and most everyone has some ..
jsteelman001
Jan 27, 2017 02:50 AM
s2000 gib
Dec 7, 2005 11:12 AM
Rickjames
Feb 28, 2005 02:21 PM
andrewchengs
Feb 9, 2005 11:59 AM
MDS2K
Apr 1, 2001 02:41 PM
