Wheel bearing problem? Something else?
I keep hearing this noise as I'm driving. It's not exactly a constant noise because I can hear it in the rotation. it gets faster as I speed up ect.
It almost sounds like a rubbing noise but there is no way my wheels are rubbing.
Also I can only hear it when my top is up.
Has anybody else had this problem? If do would you be willing to test drive my s?
Originally Posted by wanabe
the ap1s have noisy trannys- not quite a grinding, but kinda a light grinding... and mine is not that noticeable until the top is up-
Originally Posted by 7ackD1
My friend recently had this problem with his Ap1. Noise (rubbing) came from the rear driver side and it was the wheel bearing that needed replacement.
i had the same problem about 4 months ago. It made a raspy, dry, kinda smooth grinding noise...it turned out to be the wheel bearing. I bought the wheel hub and the bearing, replaced it and the noise went away! the bearings were %*$#! up yo! 9/10 chance this is the same issue you are having dude
Alright so noise started I thought I would be one side just the bearing
~$150-$200 job
Turns out I need new bearings and hubs for both sides AND a new knuckle for the driver side.
Now I'm look at ~ 1k
Damn previous owner didn't take care of it early enough. At all
~$150-$200 job
