California - Southern California S2000 Owners Southern California S2000 Owners
Wheel bearing problem? Something else?
Old 07-11-2013, 07:19 AM
MasonPardo's Avatar
Default Wheel bearing problem? Something else?
I keep hearing this noise as I'm driving. It's not exactly a constant noise because I can hear it in the rotation. it gets faster as I speed up ect.
It almost sounds like a rubbing noise but there is no way my wheels are rubbing.
Also I can only hear it when my top is up.
Has anybody else had this problem? If do would you be willing to test drive my s?
Old 07-12-2013, 03:47 PM
wanabe's Avatar
the ap1s have noisy trannys- not quite a grinding, but kinda a light grinding... and mine is not that noticeable until the top is up-
Old 07-12-2013, 04:14 PM
MasonPardo's Avatar
Hmm I wonder I that's it. Does it sound like a rotation? Does it speed up as you speed up?
Old 07-12-2013, 04:30 PM
7ackD1's Avatar
My friend recently had this problem with his Ap1. Noise (rubbing) came from the rear driver side and it was the wheel bearing that needed replacement.
Old 07-12-2013, 06:17 PM
MasonPardo's Avatar
Yeah that's got to be it. It sounds like rubbing and it sounds like the driver side. Ill still get it checked before I buy parts though.
Old 07-12-2013, 06:18 PM
MasonPardo's Avatar
Thanks guys! Ill let you know what it ended up being
Old 07-14-2013, 08:52 AM
avalencia90650's Avatar
i had the same problem about 4 months ago. It made a raspy, dry, kinda smooth grinding noise...it turned out to be the wheel bearing. I bought the wheel hub and the bearing, replaced it and the noise went away! the bearings were %*$#! up yo! 9/10 chance this is the same issue you are having dude
Old 07-14-2013, 06:37 PM
DragonHeart's Avatar
It's the wheel bearings. I had the same problem with my AP1.
Old 07-15-2013, 06:24 PM
MasonPardo's Avatar
Yeah it's was definitely the wheel bearings. In fact it was both wheel bearing plus I need I replace my spindle and ball joint. Shit.
Old 07-16-2013, 09:40 AM
MasonPardo's Avatar
Alright so noise started I thought I would be one side just the bearing
~$150-$200 job
Turns out I need new bearings and hubs for both sides AND a new knuckle for the driver side.
Now I'm look at ~ 1k
Damn previous owner didn't take care of it early enough. At all
Quick Reply: Wheel bearing problem? Something else?
