ac and heater usage
Originally Posted by sahtt,Dec 3 2007, 11:52 AM
This is not true. Everything is powered by the cumbustion of gasoline, directly or indirectly.
One thing to note here - if you use your heat but have it in defrost mode, it DOES use the AC unit to dry out the air (in most new cars) - so you will see slightly worse mileage.
Originally Posted by dombey,Dec 3 2007, 03:17 PM
right, except there is typically more juice being generated by the alternator than the system is using, so the gas is a sunk cost. Using the heater or other electronic accessories won't change your mileage.
