car debugging help - 2001 maxima
Old Apr 29, 2011 | 10:17 AM
hondafrvr's Avatar
Default car debugging help - 2001 maxima
I hope this is the right forum for this... (I thought I'd ask here before creating an account on maxima.org)
Two issues with a 2001 Maxima....
1. When starting the car up there is a very loud screeching sound that increases as I give it more gas. This goes away within 30 seconds but just very annoying. Any idea what it could be?
2. The car starts right up each and every time. BUT, immediately bogs down and dies. In order to get the car to stay on, I have to give it some gas.
In order to get it running every time, I give it some gas and hold it at a steady rpm (1k or higher) for about 30 seconds. After that I let go of the gas and car idles normally. This issue doesnt happen if I shut the car off and I turn it back on right away.
I searched the maxima forums already and have a general idea but I thought I'd get some opinions before swaying your thoughts with my findings.
Old Apr 29, 2011 | 11:26 AM
Penforhire's Avatar
Item 1 sounds like a belt problem (fan, water pump, serpentine or the like), loose or worn perhaps.
Old Apr 29, 2011 | 02:31 PM
ahrmike's Avatar
problem 1 is definitely a accessory belt problem.
Prob 2: sounds like it needs a tune up. Maybe the cold start idle function is not working properly?
Old Apr 30, 2011 | 06:36 AM
mxt_77's Avatar
For #2, is the belt screeching when the car dies? Maybe it's the alternator belt that's slipping, so you're not generating enough power to produce a good spark. Either way, #1 should be an 'easy' fix.... so take care of it and see if it helps with #2.
Old May 2, 2011 | 05:32 PM
Danny049's Avatar
#1 Belt like said above
#2 Could be several items, if it has the 3.0 V6 I'd look into cam/crank sensors or more likely the throttle body/ecm reprogram/replacement.
You should research maxima/infiniti i30 forums or consult your dealer. Some with the throttle body issue require ECM replacement and this gets pricey.
apples2kek
24
Jan 25, 2011 02:07 PM
JHooby
Feb 1, 2010 09:38 PM
mtnbiker22
Jun 7, 2008 06:11 PM
sonicjai
Sep 11, 2005 04:26 AM
tommy
Dec 28, 2001 10:08 AM
