Civic Engine Q - Interference or non-interference?
Old Sep 24, 2006 | 11:00 AM
CoralDoc's Avatar
Default Civic Engine Q - Interference or non-interference?
Could someone please let me know if a 1999 Civic DX 1.6 liter SOHC engine is an interference or non-interference design. I've been searching the internet and have gotten conflicting information.
I'm advising a friend about timing belt replacement. The maintenance schedule calls fo replacement at 105k miles, but we may want to do it sooner for peace of mind, especially if it's an interference design.
Thanks!
***edit*** Thanks everyone, topic closed.
Old Sep 24, 2006 | 11:16 AM
Ek9's Avatar
Ek9
Banned
Interference. It will bend valves if it goes.
Unless you already have it apart, I probably wouldn't do it till 105 and I'd replace the water pump and belt idler pulley/spring at the same time. It's not a horrible job, the only difficult part is getting the crank pulley loose. Sometimes you need a huge breaker or lots of air.
Old Sep 24, 2006 | 12:00 PM
CoralDoc's Avatar
Thanks for the confirmation. Now, our plan is change it out between 100 and 105k miles, and for sure do the water pump, pulleys, etc.
I have a nice 1/2" breaker bar and enough air to get the crank bolt off a Miata engine that was sealed in place with loctite.
Old Sep 24, 2006 | 02:35 PM
Slows2k's Avatar
Moving to Car talk.
Old Sep 24, 2006 | 07:03 PM
JonBoy's Avatar
Basically, there are only two (I think) relatively modern Honda engines that are non-interference. One is the '98-'02 Accord engine (F23) without VTEC (the others with VTEC actually won't interfere as long as you aren't in the VTEC engagement range) and another is one of the Civic engines - I forget which one, but I think it's an early 90's engine.
solitarycheese
Jan 11, 2016 12:00 PM
berlina2ks2k
Mar 8, 2013 04:20 PM
S~Factor
17
Oct 5, 2011 03:45 PM
newnan-s2k
Feb 16, 2009 05:19 PM
simons2k
Jun 11, 2006 09:39 AM
