Delaney Power Extractor Engine
Old Mar 11, 2008 | 11:27 AM
jhon077's Avatar
Default Delaney Power Extractor Engine
Hi All,
I came across this website powerxtractor.com through a friend of mine
and this new engine sounds pretty impressive, but I don't know enough
myself. What do you all think, is it really good as my friend said?
Thanks in advance for help
Old Mar 11, 2008 | 11:48 AM
seung's Avatar
ack, i clicked this thread because i read the title,
"disney power extractor engine."
i was scared we'll all soon have micky mouse logos on our cars.
sorry.
Old Mar 11, 2008 | 11:50 AM
Wildncrazy's Avatar
Before you click on any link you need to check the age of the poster.
0 years and 0 days with a 60.3 posts per day??
SPAMMER!!
Be banned before the end of the day.
Old Mar 11, 2008 | 12:19 PM
ace123's Avatar
28.1 PPD at 218pm, when this was posted at 127PM => this might be his only post. 1 hour member => PPD = 24*(# of posts)
Old Mar 11, 2008 | 12:42 PM
ace123's Avatar
sounds too expensive right now.
you have to deal with timing the engine to make an advantage of the negative pressure of say 30psi (i have no idea what pressure would actually be needed to get 'close enough' to the ideal vacuum state) sucking on your pistons when they're at BDC. i think that would have to either sap power or lower your compression ratio, depending on how you chose to time it.
to take it further and dodge that bullet, remove the intake valves entirely. put several seals just above BDC in the cylinder wall, and insert the intake/exhuast 'supercharged' (high pressure) blower nozzles here. blow out the exhaust gas with a several blowers, distributed radially around the cylinder wall. then blow fuel in using another or the same blower set. you now have direct injection with improved volumetric fuel distribution, you keep the '2-stroke' advantage, and you dodge the negative pressure problem.
however, you still have to figure out how to get seals that have infinite fatigue life at your rated temperature and pressure.
all this would probably happen at a cost of only $50k per 2.0L engine, provided we can sell at least 10 million units. until that makes sense in our economy, we'll keep buying superchargers and wanting higher octane fuel!
Do$tylz
Oct 18, 2006 02:51 AM
Bigeggroll
May 6, 2005 06:32 AM
Wisconsin S2k
Nov 9, 2002 03:29 PM
TeamRedlineS2k
Aug 29, 2002 10:54 PM
Garyj
Nov 30, 2001 05:47 PM
